Question about SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE RAID PCI Controller Card - RETAIL (DSSBATA133RAID)
Need win 7 drivers for SD SIL680-Raid card - SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE RAID PCI Controller Card - RETAIL (DSSBATA133RAID)
Posted by omeditonn on
Martin Murray
    President:
  • 1,623 Answers
Try the vista driver it should work ok
32 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-32bit.zip
64 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-64bit.zip
if you found this useful please vote for me
Posted on Apr 22, 2011
Need win 7 64bit drivers for SD SIL680 usb-3 card
You have asked your question in the wrong area, but to answer you:
It would appear that the SIL680 is for IDE, a hard drive interface and not USB. I'm not sure if there's a different model, but I'm not finding much on it. In the event that you really do have the IDE device, here is a driver link for Vista x64, which should do the trick:
Nov 06, 2014 | Computers & Internet
Advent modena m202 sd card reader driver
temm me operating system....win xp? win vista? win 7? 8?
card reader driver is from JMicron...
Sep 10, 2013 | Advent Computers & Internet
Sd-pex-vt4e4i windows 7 driver
Sybe makes your card. It was sold by many - including Newegg, here.
Here's Syba's support page for the SD-PEX-VT4E4I. It says no driver are needed, but only is supported up to Windows Vista. You want to contact support directly but I suspect this is End Of Life.
Apr 27, 2013 | SYBA PCI-Express USB2.0 + 1394a FireWire...
I CANT SEE MY HDD PORTABLE WHEN I INSTALL WINDOWS 7.I HAVE NO DRIVER OF SD-SIL680-RAID CONTROLER
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
http://download.cnet.com/sata-driver-intel-ver/3000-2122_4-162224.html
if this is not the right driver package
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 24, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
I'm looking for an sd card driver for a tc1100 tablet pc with win 7
Windows 7 installs the correct drivers but if you are looking for drivers to enable cards larger than 1GB SD card, you cannot. This is a hardware limitation in the "4in1" card reader.
Jun 29, 2011 | Compaq tc1100 Tablet PC
Have an SYBA PCI IDE RAIDx2 and very urgent need the driver for Windos 7 Ultimate x64. The VIA site is out of service..!!
hi I found this link below for all syba driver updates and downloads, hope this helps.
http://it.us.syba.com/support_download/download/index.html
Feb 13, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
I am attempting to install Windows 7 on an AlienWare M7700 D900T laptop, but Windows Setup will not recognize the hard drives. When first I boot up the laptop the hard drives are clearly detected, IDE...
It is a 2005 machine and was designed for Vista so an upgrade from Vista to Win7 may work as the drivers will need updating as it loads one OS from the other OS.
A bios update would possibly help also.
Jan 16, 2011 | Alienware PC Systems M7700 Notebook
NEED DRIVERS LOST DISK SD-SIL680-RAID
you can download from web site of board if you can use the public libray system jim
Mar 25, 2010 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Set up raid 1 with win xp--------47JFR controller
load the software driver for this card
then open the window of this software by opening it from program files , you would see help on this soft ware . select raid 1, else is done auto .you must have minimum two drives to make a raid
Sep 12, 2009 | Dell 47JFR - (Refurbished)...
SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE RAID PCI Controller Card - RETAIL (DSSBATA133RAID) Logo
Top SYBA Computers & Internet Experts
k24674
Are you a SYBA Computer and Internet Expert? Answer questions, earn points and help others
