Hardware & Accessories Logo
Posted on Apr 22, 2011
On the Noma timer Mod 49550/tm151p how can you tell when the switch is on
A
Anonymous
1) Noma is old Intermatic brand name used by companies today to brand their timer.
2) Noma is usually associated with Woods timers.
3) Woods numbers also frequently start with 495 and with TM.
For example Woods has 49588 49556 and 78 84 29 28 62 57 33 53 65 44 68 32 77, but 49550 does not show
4) It is likely that you have a Woods brand timer.
5) Add a comment with in-focus photograph of timer for possible identification
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
6) Open following link to possibly identify timer, and then add a comment saying which timer is same-similar to yours.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Read troubleshoot section to see if your answer is there:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
2answers
MANUAL FOR NOMA TIMER MODEL NO 052-8805-4
This particular model is very easy. It is a NOMA 7-Day Mechanical Vacation Timer, Non-Programmable, Indoor timer.
turn the centre dial until the pointer is at the current time, set the switch at the top to 'Auto' and that is it. Plug it in, plug a device like a light into it and go on vacation. The timer switches the light on and off at somewhat random predetermined different times each day.
https://www.canadiantire.ca/en/pdp/noma-7-day-mechanical-vacation-timer-non-programmable-indoor-white-0528805p.0528805.html
https://www.google.com/search?q=noma+timer+052-8805-4+manual
I have a Noma Model 1600 7 day programmable wall switch timer. I have lost my instructions to program it. I need instructions!
Contact Canadian Tire to request assistance. (Noma is sold by Canadian Tire.)
I couldn't locate that model number. You can use the Comment menu to add information to your question.
Could it be any of the pictures at the link below:
https://www.canadiantire.ca/en/noma-lighting-heating-cooling/noma-indoor-lighting/noma-indoor-light-timers.html
Hi, I have a Noma moonrays 88 watt timer with two buttons on the front and a display from 0 to 9. the top button seems to be a manual/auto switch and the bottom one has a clock symbol, but i can't
1) Copy following link for to identify timer, and possible instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#Moonray
2) Add comment and say what you discover about setting timer
3) Look on timer, and sometimes the instructions are printed on paper label
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
NOMA 1000 watt Photoelectric Timer manual
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
2) If timer has gone defective, then N1502 has 1 year limited warranty.
Timer is rated for 8 amps.
125 volts x 8 amps = maximum 1000 watts
2-prong output.
3) For heavier duty timer, with 3-prong grounded output, choose N1506 timer
I have a noma 49550 and the timer let the turn on and the wheel spins as well but it doesnt shut off even with the pins and i dont know what the wheel at the top is for, is that the issue???? please help...
I don't have repair for defective timer.
The wheel at top is probably the issue. Move the wheel with your thumb and experiment with the timer.
As a general rule, the timer will not bite you.
Open following link for analog timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
My files show that 49550 is analog timer with trippers that install on timer dial.
http://waterheatertimer.org/Woods-timers-and-manuals.html#49528
1helpful
How to set a Noma outdoor timer
You posted under Noma timer.
Noma timers are one of the names used for Woods timers.
You posted under 6-button outdoor timer.
Here is a link to 6 button outdoor Woods timer, to help identify your timer.
If this is not your timer, scroll through page to identify timer.
Manuals are posted with each timer, add a comment with specific timer number if you want me to write out steps from the manual once you identify the timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
geno_3245_173.jpg 6 button outdoor 7-day timer
geno_3245_174.jpg 6 button outdoor Week timer
Looking for instruction manual for noma digital indoor light timer model 052-8814-2
I have extensive files on timers.
I don't recognize Noma 052-8814-2
Noma is an old Intermatic name that is now used by many companies to describe many models of timers.
There is wide bleed-over of timer names and designs across different manufacturers.
1) Please add a comment and post photo of your timer so I can match with existing manuals.
2) Add a comment and describe timer in detail so I can match up a manual if possible.
3) Open following link to see all Noma-Woods timers I have on file.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
4helpful
Programming my Noma photoelectric switch
I would like to figure out out to program my NOMA photo electric switch Model Number N 1502
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
