SOURCE: rca 52 inch projection
That was it. I found cp150 and it was bad. I replaced it and my tv works like new. thank you very much for your help.
SOURCE: 52 inch rca rear projection
I repaired an RCA 52" TV. I found two capacitors on the board that were bad. They were bulged on the top. This seems to be a common problem on many projection TV's. Try searching this website using the model number as your keyword.
Hope this helps,
Dan
SOURCE: 52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
SOURCE: i own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
