Well if it won't charge then it could be the batteries are too low for the charger to pick up or the charger is not working. If you have a voltmeter set it on 200 vdcand plug it into the 2 outter holes of the charger port located under the front of the joystick. Without the charger plugged in you will read the battery voltage and it should read 25-27 volts fully charged Now plug in the charger and the meter will be reading the charge voltage and it shoud be 27-30 volts. If you are reading 27-30 volts with the charger plugged in then the charger is working Hope this helps you
