Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
Were can i buy a li_lon battery.part no.mh29654,modle no.mcr18650.please.
Posted by barryplumb11 on
Mike F
    New Friend:
  • 59 Answers
Here is a site that provides quality replacement batteries for the iM600 speaker dock:
Battery for iM600 Speaker Dock
Posted on May 30, 2013
Anonymous
  • 4 Answers
Anonymous
  • 449 Answers
EBay is a great source for oddball batteries.
http://cgi.ebay.com/Altec-Lansing-BATTERY-IMT702-IM600-IMT620-MCR18650-3-7-/160572757568
Or just search eBay with the batter part number.
Posted on Apr 22, 2011
What do I do if my phone keeps shutting off when its fully charged but when I try to take out the battery and put it back in it just starts blinking like crazy?
Your battery is dead. You can simply buy another of the same battery. Rechargable batteries do lose their charge for good after a certain amount of time.
1helpful
Li-lon polymer rechargeable battery pack
Look at the battery pack for a designation of the pack---Google that number or the model number of the unit with "battery".
I had got bl-4c 860mah battery of nokia and its big problem is its battery back up is so poor..how can i improve its power backup
li-lon batterys like other batterys burn out over time they stop holding as much power as capable the fix is easy buy a new battery and it will restore you to full power
merry christmas
5helpful
2answers
Battery part no Mh29654 for iM600 speaker need to purchase a new battery. Proving to be a night mare to obtain as this has 3 wires with sq connecter.Model no McR18650 3.7v
buy a cilyndrical 3.7v battery,a bougth a onu with 3000mah. and use the conectors from your old one,they are built-in circuit take it apart and reuse it
1helpful
2answers
Battery
The new battery goes in the back of the Altec Lansing imt702. Remove the two screws on the lower back of the unit. The battery is connected via a clip connector. Simply press on the raised end of the clip, and pull off the other end of the connector. The battery is a Lithium-Ion 18650, 3.7V, at least 1800mAh. If you can get a battery with a higher-rated mAh, this will give you longer run times. It might be difficult to find a matching power connector on end of a new battery though. The unit will still run with the battery removed, but of course, will not power without the AC adapter connected to a wall outlet. If your unit has problems, continuously asking to Reset itself, or display+buttons flash (with volume increasing +1 for each blink), this indicates a charging problem. The battery needs to be replaced or removed immediately. You can reset the power manually by holding down the metal clip at the back of the unit for a minute, or just closing the leg/stand to see if this works. To reset unit's factory settings: hold down power & radio << channel buttons for 7 secs, press Power when asked to Reset?, Region=1 for US stations, & press Power again to set Region. Note that the battery is being drained even if the unit is off, so keep the AC connected; completely draining a well-used Li-Ion battery may shorten the rest of its battery life. Remove the battery from the unit if not in use for long periods.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Download file
  • Copy link address
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
Top Altec Lansing Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
