Question about OKI MICROLINE 520 Matrix Printer
Using Win7 - switches to NLQ mode every time regadless of driver used - Okidata Elite (Microline) 520, Okidata Elite (IBM) or Okidata 520. Tried changing drivers - none other available for Win7. With the (IBM) drivier it doesn't print at all, with the (Microline Driver) it won't print the entire page length.
  • OKI Master
  • 757 Answers
This is a SNIP of a rather LONG FIX:
Found here:
http://forums.windrivers.com/showthread.php?7080-RESOLVED-Okidata-Microline-184-Turbo
"Just purchased this thing and am running it a machine to print checks with (Win95, p1-200, 48 Mb ram). The Oki dot matrix printers don't give you drivers, they tell you to use the drivers from Win95 disk. Sure... (just lazy if you ask me :-) OK using the Oki Microline 184 IBM Turbo driver the thing works fine, EXCEPT that it *always* prints in NLQ mode no matter what the settings in the control panel, it just switches to NLQ before each print job. So... we switch to a "generic text" driver and it works fine that way EXCEPT that it no longer recognises the custom paper length (8.5" wide X 7" long) Now here's the wierd part... IF I switch back to the win95 driver, re-accept the custom paper size, print a test page (in NLQ of course), switch back to the generic driver, re-accept the the custom paper size, switch the printer to normal (non NLQ), and print it works fine with the custom paper size and non-NLQ mode until the next time it needs to print. The printer remains ON 24/7, so its not reseting itself. It just seems that with the Win95 driver there is no way to set it to print in anything but NLQ AND the generic driver refuses to keep the custom paper sizes in memory. Anyone seen this before? Never came accross this myself. I may just end up sending this thing back and getting an Epson or someting else."
AND THERE IS THIS:
"This is like going back to the dark ages....most of those old impact printers had dip switches to set things like default print quality. Additionally, Oki's usually came in two 'flavors'--plain Oki and IBM Oki. It's important that you install the correct driver between the two options..."
Anthony
Posted on Dec 25, 2017
Anonymous
SOURCE:
Desmond Pillay
  • 40 Answers
SOURCE: How to disable the Okidata from printing double space
Try reseting to factory defaults.
Power unit on while holding down "tear" and "FF Load" buttons.
Hope this helps
Dezzi
Posted on Dec 31, 2007
scrodamoon
Wesley Gardner
  • 659 Answers
SOURCE: Okidata microline 521
You should clean the printer every six months (or after
about 300 hours of operation).
1. Turn the printer OFF.
2. Remove the paper from the path.
3. Open the access cover and remove the pull-up roller
assembly.
4. Use a clean, dry cloth to dust the area around the
carriage shaft and platen. Be sure to remove any loose
particles of paper.
5. Reinstall the pull-up roller assembly.
6. Close the access cover.
Never use solvents or strong detergents on the
cabinet — they could damage the housing.
Posted on Aug 11, 2008
Desmond Pillay
  • 40 Answers
SOURCE: alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Posted on Nov 29, 2008
Anonymous
  • 259 Answers
SOURCE: How to Connect an Okidata Microline 321 to a new computer
If you have the software I would install it and see if it works if it does not Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} you may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Posted on Jan 26, 2009
Anonymous
SOURCE: microline 391 okidata continous feed leaves a page of space
We have downloaded the manual and will see if we can figure it out.
Thanks
Posted on Apr 07, 2009
OKI MICROLINE 520 Matrix Printer driver
You can get any driver you want by installing : Driver Genius - the latest version .. and let it search through the internet :)
btw , here's a ( worked & safe ) link for D.G :
http://depositfiles.com/files/k7bzoizzb
Hope that link helps too :
http://www.driversimple.net/Camera-MP3-Player/Okidata-Oki-Ml-520-Elite
Good luck :)
Jan 10, 2013 | OKI MICROLINE 520 Matrix Printer
Install ibm proprinter ii in windows 7
Hola Gabriel, puedes dar mas datos. Could you give us more info please.
Ya intentaste con los drivers originales de Okidata?
Did you already try with its original drivers? http://my.okidata.com/dsdownWeb.nsf/driverlookup/D7BFA5764F4784E98525767E00689DED?OpenDocument
Sep 17, 2012 | Matrix Okidata Microline 320 Printer
We had a computer crash that required replacing the computer we had with one running Windows XP w/SerPk 3. We are still using the okidata microline 320 turbo that we used with the old computer. We are a...
The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available.
If the driver did not work, try to use the IBM Proprinter or Epson LQ driver.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 16, 2011 | Matrix Okidata Microline 320 Printer
Printing from 1989 DOS program "Labels Unlimited" with same
sound like a parallel connection.
Try this:
open a dos command prompt and type this command:
dir>lpt1
this would try to print through the dos mode if you connections is good it should print something.
Mar 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki Microline 520 printing slow
Your printhead alignment is out thats why it prints slow
Jul 17, 2008 | OKI MICROLINE 520 Matrix Printer
Installation software
No need for driver under WinXP it automatically detect
Or you can find the driver in : http://www.mj-printers.com/drivers/okidot.html
Apr 16, 2008 | OKI MICROLINE 520 Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 320 turbo 9 pin printer
What driver are you using, you should try the IBM Proprinter Driver.Hope this helps.
Dezzi
Feb 11, 2008 | OKI MICROLINE 320 Matrix Printer
Oki microline 590 elite
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Dezzi
Dec 12, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MICROLINE 520 Matrix Printer Logo
117 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Thomas F. Schneider
Ekse
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
