Question about EliteGroup ECS u-Buddie UB-Em22+ PC Desktop
Power on led fly lead fits where?
Hi
I bought a barebones U buddie 4m23/24, I took the lid off and there was a lead from the 'power on' led just hanging there - where does it fit? (and which way round)
The accompying manual and quick assembly sheet do not mention it - in fact the manual is not very helpfull at all - is there a more comprehensive manual available anywhere tht I can download?
thanks
Barry
Posted by Busybaz on
Looking for power adapter
hard to find.
but u can use 12v DC supplier with that connector line from the dead PSU.
it is a 4-pin connector, but only 2 wires ( positive & negative ) in the line cable.
Oct 28, 2009 | EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
Need front panel pin colour code
The two green cables are for power LED, one + and one -. Then there are two yellow cables for the HD LED, with one + and one -. The red ones are for ON/OFF (power button), and the blue are for reset. So yeah, you are technically right if I understood what you said xD
May 21, 2009 | EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
No boot up.
Power supply is easier to troubleshoot my local pc shop has used ones for $5 or if you have one laying around make sure you have one with the proper mobo connector 24pin will sometimes fit 20 pin as long as there are no transistors to close to plug just turn pc off unplug all drives and mobo plug in good supply and turn on if it works thats the problem if not probably mobo
Apr 10, 2009 | Shuttle SK43G (tsk43g) Barebone
My ez-d1s4-2 elite group computer
Sounds like the computer is likely overheating. Verify that all fans are running, replace any that are not and dust out the computer. If that does not work then you might need to find out exactly which part is overheating (probably the CPU) and either replace it or get a better cooler for it.
Sep 07, 2008 | EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
Cpu issues
The only way to fix it without basically replacing the whole computer would be to replace the CPU cooler but that might not even be possible. You can try cleaning out the case to get rid of the dust. In any case the CPU has to work harder to decode the video which will cause it to heat up which in turn causes the cooling fan to spin faster.
Aug 28, 2008 | EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
POWER CABLE
Like This One?
Delta AC Adapter (Model:ADP-150BB)
Google the p/n maybe you can find it elsewhere
Apr 30, 2008 | EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
EliteGroup ECS u-Buddie UB-Em22+ PC Desktop Logo
Top EliteGroup Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
