Refrigerators Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a jennair refrigerator mdl#jfi2589aes took the ice cube storage box out to fill cooler, when i put it back in the ice cube maker will not dispense ice cubes to the storage box, ice maker is making ice cubes but will not drop them in storage box
Anonymous
Level 2:
Scholar:
  • Expert 83 Answers
  • Posted on Apr 22, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
83
Questions
0
Helped
24904
Points
232
Hi
This usually is because the drive on the ice box is not engaged,
1. Remove the ice box and empty it into a bowl
2. Replace the ice box and turn the auger (spiral metal inside) until it locks into the drive motor
3. Ensure the box is pushed back as far as it will go
4. Put ice back into ice box
5 Try dispensing ice again
This is a common problem as there are teeth on the back of the ice box that have to align with the drive motor in the back of the freezer
Hope this helps
Gordon
1helpful
Ice maker on refrigerator does not work at all
Notwithstanding the ABSENCE of MAKE+MODEL...
(REFRIGERATER or ICEMAKER)...
Nothing came through with your "question"... ERGO
Most, generally & typically should be in front of everything that looks or sounds like a FACT.
Every ICE MAKER (I've ever worked on)has an on/off control...
Find it... turn it off, on, off & on several times (cycle the switch
(like lower the FILL wire ... or operate the on/off switch)).
ICE-MAKER heads are a relatively simple device with motor driven electro-mechanical sequencers that time water fill (adjustable), cube "done-ness" ((firmness by adjustable temperature)... and then "operate the fill valve... fill the tray...
Rotate the tray and eject the cubes.. refill with water...
If you can see or feel ice in your TRAY your...
you have NO ISSUE with your WATER VALVE...
To test this... use an ordinary water bottle and Put some water in your ICE TRAY...
Check back in an hour ...if your cubes have been NOT deposited into your ice bin... your ice-maker is turned off, has a open fuse or is defective & needs repair.
If it has ejected your cubes but you have not been refilled your WATER VALVE is defective...
replace it.
Hope this helps.
Ice Box wont stay running
Hello Jeff;
My name is Peter. I am a retired field service refrigeration technician.
Ice Box? You must not be from the Glen Burnie, Maryland USA area.
Ice boxes or ice maker have several controlling factors. Some are repairable. Here is how they work:
1.) Your ice maker will harvest ice cubes 8 to 10 times within 24 hours.
2.) You have a control module in the front of your ice maker. This is like a small control board. It has a motor and plastic gearing system. It also control the lever system to fill your ice bucket.
3.) The control module tells the solenoid valve in the lower back right hand side of your unit to open and fill the ice cube tray.
Then you have a temperature sensor that tells the control the ice cubes are frozen.
4.) You either have a flex ice cube mold that will activate or a heater under the mold tat will turn on for a set period of time to release the ice cubes from the mold.
Send me the model number of your unit and then we can trouble shoot together.
Why would my ice maker start freezing all my ice cubes together?
ice maker made cubes, but you shouldn't put in freezer any warm staff, its melt ice for while after freezing them together
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
2helpful
3answers
When is ice maker activated ;with bar up or down ??
The bar will sense ice cube level in the holding bin. If it is all the way down it will tell the ice maker to make more ice. When the maker "dumps" the ice the bar should be all the way up and will lower to check the level.
Crushed Ice only
I have a similiar problem. I have dumped the ice and started ice maker again. It make ice but will not despense ice cubes.
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
1helpful
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Ice maker sprays water into the ice storage bin
you need to remove the i/m from the freezer and make sure the "fill cup" doesnt have an ice blockage. thats where the water has to funnel into the mold. it can get a drip into the cup and then freeze in the cup. clear it out once and try it again, but if it happens once or twice again , then you might have to replace the water inlet valve.
Ice maker problems
If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
