Question about GE Dishwashers
Dishwasher not cleaning glasses
Can you tell me what else I can try to get my glasses clean in the upper rack of my GE Profile Dishwasher--model #: PDW7880JD1SS. The sprayer under the glasses doesn't seem to be spinning, and if it is, not enough. I have all kinds of crud inside my glasses. I've checked to make sure the holes in the sprayers are clean, that it spins freely and that the dishwasher is level. I use Cascade granuals and we have good water pressure in our faucets.
Posted by teresak66 on
  • Anonymous Oct 08, 2008
    my wife is sick of cleaning the dishes twice
  • sixrealms Nov 24, 2008
    New and recent problem, glasses, coffee pot, etc., the inside of containers, are not getting clean, irrespective of them being loaded on top or bottom. I've changed detergents and there's been no improvement. If I wash several times using vinegar, they do come out clean.
5 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Posted on Jul 31, 2007
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Posted on Nov 07, 2007
Anonymous
  • 105 Answers
SOURCE: dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Posted on Feb 24, 2008
Jeff Meyer
  • 423 Answers
SOURCE: not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Posted on Apr 05, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Upper rack sprayers not working on LG ldf7811 dish washer
Check the pump out. Even though the Hose is and tubes are clear it does not necessarily mean that the pump is not pumping water to the top sprayer. One way you can do this is take off the upper spray tube and lay it in a glass or bowl and turn on your machine for a minute or so to get the water flowing if it flows then I would take off the spray assembly itself and make sure that there is no blockage on the bearing race
Posted on Apr 08, 2009
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Apr 14, 2016 | GE Dishwashers
Sand on inside of cups and glasses on top rack of dishwasher
it souds to me like lime scale detaching its self from the heater element.
try calgon, it should fix it
Jun 03, 2012 | GE 24 in. Profile PDW7880G Built-in...
Always little crumbs in glasses on top rack
Cleaning screens is part of regular use of the dishwasher and how to should be included in the user guide. If you don't have one look for it on the internet by searching for user manual for your model number which can be usually found on the side of the door or frame where the door closes. Good luck.
Feb 13, 2018 | GE Nautilus 24" Built-in Dishwasher
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishes in top rack not getting clean
If you live in an area with 'hard' water (having more than 5 ppm) you may require a whole-house treatment system to eliminate the mineral content that will wreak havoc with any water-related system (including your water heater).
If that is not the case I would have a service call to check the upper level service arm, which must be pushed in to a hole in the back of most units in order to get the water to flow in.
Oct 01, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dirt and residue left on glasses
wash glases alone ad a jet dry aditive to detergant  Vitally
Jan 26, 2009 | GE Profile PDW8600J Built-in Dishwasher
Glasses on upper rack getting food residue during cycle
is there anything blocking the spray or plugged in the spray arms check that
Mar 28, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
97 people viewed this question
Top GE Dishwashers Experts
Mike
Nathan Van Boven
Nathan Van Boven
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
