Question about Toshiba SD-3980 DVD Player
I own a Toshiba SD-3980SU2 DVD Video Player. I keep getting an Incorrect Disc comment, and bad comment. I an using DVD-RW discs. I have tried disconnecting and reconnecting the player.
Posted by mykiks on
Demonic-2011
  • Toshiba Master
  • 513 Answers
You are probably using incorrect disc formats in this DVD player; try DVD+RW if you must use re-writables, or DVD-R (finalised in a recorder or burned on a PC). I doubt this model supports DVD-RW, so the problem wouldn't be with the player; it would be the formats of the discs you use.
Don't use DVD-RW discs in this player if it does not support that format.
Posted on Apr 24, 2011
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
I have a Toshiba DVD player SD K741. For the past few days, when I load the dvd, I receive a message on my TV screen "Incorrect Disc." What can I do to correct this?
incorrect disk error are common with the user putting in a disc that is not compatible with the player, in most cases it would have been a RW, that was written incorrectly. If this is not the case and it is a original disc you might want to purchase a cleaning dvd witch goes in and cleans the lens.
If that does not work then the unit's lens might be defective at this point.
1. Try other disc
2. try a cleaning disc
If those do not work then the issue is with the lens.
Thanks for your question please do not forget to leave a rating.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2010 | Toshiba SD-K740 DVD Player
Toshiba DVD player SD3980 Keep getting an incorrect disc or bad message. Have turned it off & tried other discs.
check spindle motor,flexible wire, if this two is ok then your laser is at fault, note; be aware on installing flexible wire if its incorrect it may impair the operation of sled motor , clean clogs and dirts on sled gears
Oct 13, 2009 | Toshiba SD-3980 DVD Player
Toshiba sd 220e dvd player
CDR
CDRW DVD-R
DVD-RW
DVD+R
DVD+RW
DVD+R DL VCD
SVCD It plays PAL and NTSC apperently.
Here is a link to comments and more info of what this player plays-
http://www.videohelp.com/dvdplayers?DVDname=sd+220e&Submit=Search&Search=Search&dvdportable=&dvdchanger=&dvdtv=&chipset=&orderby=Name&hits=50
Hope this helps.
Aug 15, 2008 | Toshiba SD-220E DVD Player
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
MP3 files on a DVD+RW disc - not all display or play
Toshiba SD-3990 does not recognize DVD+R/RW discs. You need DVD-R/RW
Jan 09, 2008 | Toshiba SD-3990 DVD Player
Device display now says "bad" and TV display says "Incorrect disc"
Sounds like the player has a dvd mech/picup problem, will probably require a repair that is more expensive than a new player, they are as low as $30 and personally I dont even try to repair my own, I just go buy a new one. There may have been some dirt on the disc that is blocking the laser if you want to try a cleaning disc I doubt it would hurt it anymore.
Jul 07, 2007 | Toshiba SD-K741 DVD Player
Dvd not reading disc it just wrote
you might try + media also see if there is an option to finalize the disk.
Apr 19, 2007 | Toshiba (SD-R6112) DVD-RW Burner
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
DVD PLAYER
Hi Koji, My Toshiba DVD player does the same. It stops playing the disc, and the icon for incorrect disc displays. Often I cannot even start a movie. I keep getting BAD on the readout display also. I try hitting the player, or the stand in which the player is sitting, and sometimes it goes away and the movie plays. I will never buy Toshiba again.
Dec 25, 2006 | Toshiba SD-3980 DVD Player
Toshiba SD-3980 DVD Player Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
