Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
Hello! My refrigerator GE PFS22SISSS model stopped cool and the display is black and only turn on when touched any button, turn on "000" in the indicator of the freezer and of the refrigerator, only addiction turned on the light in the fridge but the compressor and the fan does not. Thanks for the help
5 Suggested Answers
Anonymous
  • 237 Answers
SOURCE: refrigerator and freezer
Does the compressor click on and off every minute or so and is hot? That would likely be tripping on a thermal overload due to not being able to start (bad motor starter on the compressor). If the compressor is running normally and warm then you may have a froze up coil. Take the lower rear back sheetmetal cover off the inside freezer section and look at the coil. If it's frozen block of ice basically the defrost cycle is not working and the ice has blocked the air flow through the unit. (could be bad defrost heater, defrost timer or defrost t-stat). If the compressor is running normally and warm and you see no ice or even frost on the coils then you have a sealed system problem that usually means most if not all of the refrigerant has leaked out of the system (or a blockage/restriction in the system). This would be the worst case since it means a whole bunch of money to repair. Let us know what you find out and we can have a better idea on what to recommend.
Posted on Nov 24, 2006
robert samples
  • 1314 Answers
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
Anonymous
SOURCE: fridge compressor hot. inside of
how to install refrigerator compressor
Posted on Jul 04, 2008
Anonymous
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
Anonymous
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
Samsung rs263tdbp and demo/cool off mode will not turn off
from the manuals Page 1. Activating/Deactivating Cooling Off Mode When the refrigerator is in Cooling Off Mode (aka Demo Mode) the display will read "OF OF, O FF, or OFF OFF." Cooling Off Mode prevents the unit from cooling. It is used by retailers to display units without wasting energy.
Note: Models without digital displays will display scrolling lines when the unit is in Cooling Off Mode.
Tip: If your display panel has buttons that have to be pushed in to perform any functions, replace the word "Touch" with "Push" or "Press" in the following steps.
  1. Touch and hold the top two buttons on the left side of the display panel.
  2. Important: You must touch the 2 buttons at the exact same time. Not doing so will result in an unsuccessful attempt to activate/deactivate Cooling Off Mode.
    [img src="http://www.samsung.com/us/system/support/content/2011/04/25/h5408/Demo_Mode_250_Pix_1.jpg" align="bottom" border="0" height="127" width="250">
    Notes:
    • As long as the display panel is located on the exterior of the left door of your refrigerator you will use the top two buttons on the left side of the display panel to activate/deactivate Cooling Off Mode.
    • If your display panel is located inside of the unit along the door frame you will need to locate the words "Cooling Off (Hold 3 sec)" printed on the panel. The Power Freeze and Freezer buttons are the two buttons used for Cooling Off mode on these models.
    • Wi-Fi Touchscreen displays on RF4289* and RSG309* are exceptions to this article. Cooling Off Mode is activated/deactivated through the settings menu.
Apr 01, 2014 | Samsung RS263TDBP Side by Side...
Pfs22sisss the temperature control displays quit working. unplug unit from the wall, plug back in and the displays work for a while then go out. also the condenser fan isn't running. when the compressor is...
Hello Rogerspray,
I understand that you are having a problem with your GE refrigerator the fan is not working and the power board is not working. The fan should always run when the compressor is on and sometimes when the compressor is off as it is to circulate the air.
You will need to replace the fan this can be removed and taken to any local hardware store and purchased as the are not expensive.
It sounds like you also need to replace your power board. I have located you one on Sears Parts DIrect it costs $91.33 and can be located at this link power board.
In-order to replace both of these items you will need to:
1. Turn off power
2. Remove cover panel
3. Disconnect quick connects
4. Remove item
5. Install new item
6. Replace wire to same terminals
7. Replace cover
8. Turn on unit and check
Replacing these items should take care of the problem that you are experiencing.
Thank you for choosing FixYa.com
Justinbur167
Apr 25, 2011 | GE PFS22SISSS Stainless Steel French Door...
PFS22SISBSS CLICKING AND NOT COOLING
Hi this is the main control board, part # WR55X10942, this should fix your problem.
Thanks for using fixya.com, if this has helped please rate my answer. Thanks!
Mar 30, 2011 | GE PFS22SISSS Stainless Steel French Door...
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
The freezer on our GE PFS22MISBBB will not cool
When you say your freezer is not cool then there is nothing cool in the refrigerator is that correct? My concern is the main control board or defrost is not taking place. Could you tell me if after unpluging the refrigerator and touching the top of compressor if it is hot or cold or too hot to touch. On models like yours the control board controls most functions and that includes defrost and starting and stopping of the compressor. If there are visible burns on either side of the control board or signs of heat on the plastic relays or melted solder connections would indicate the problem. Let me know this and I will walk you through the steps of diagnosing the problems. Thanks for having your model number available, this is rare, Thank You, Sea Breeze
Jul 08, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Inside Dsiplay Not Always on
Most likely it is the Main Control Board also called the Motherboard. It is located on the rear of the unit behind the smaller axcess panel. Becareful with the wiring if you attempt to change the board. There is a slight possibilty that it is the dispay board, but it is unlikely.
Nov 25, 2007 | GE PFS22SISSS Stainless Steel French Door...
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
