Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
KDF-55XS955 I have a problem were there is no picture on TV but sound is OK. I turn off TV and then comes back OK. Picture is good and not dark as it was case when I needed to replace lamp. I have replaced lamp last year. Is it directv reciver? There is no blinking lights on front of the TV. Thank you for help.
Posted by tekstilac on
L Vincent Testa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 721 Answers
First reset direct tv box unplug for 5 minutes then plug back in because it could be direct tv
if this does not work replace the lamp anyways see the link below for part and how to do it
Sony Grand Wega Fixed Part 2 11 18 10 Amazon com Compatible Sony Replacement TV Lamp for KDF 55WF655 KDF...
Posted on Jan 02, 2018
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
This sounds so simple, but this is what i gathered from Sony's website. Sounds to me like it may be a service issue.
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Posted on Dec 05, 2008
Dewayne Turner
  • 87 Answers
SOURCE: Projection lamp casing melted.
This will be covered covered under warranty by Sony. If you will call 800-282-2848 you can locate a Sony authorized servicer that should be able to repair this at n/c.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Feb 09, 2009
Anonymous
  • 53 Answers
SOURCE: I have a KDF-55XS955 or KDF-60SX955 it has lots of dark blue dots
You are correct. It was under extended warranty from Sony.
Unfortunately, that program ended on December 31, 2008. Your set is no longer covered by Sony for this problem. It is, however, still fixable.
Expect to pay about $500-800.00 for the Light Engine and around $200+ in labor to install it. Once in, though, the light engine will take care of those blue dots.
Posted on Jan 22, 2010
Anonymous
  • 72 Answers
SOURCE: Our Sony KDF-55XS955 turns off after 60 to 90
That is a definitely a lamp issue - Get a NEW lamp (with casing) online, have it shipped overnight - install according to your user manual (this is a common mainenance issue) and you should be fine. Or just call Sony or go to their website and they'll ship it directly to your home. Best Regards,
Beach TV Repair
Treasure Coast, FL
Posted on Jul 04, 2010
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Hi, My Sony Grand WEGA KDF-55XS955 55 in. Rear
6 times red blink is an error code that indicates no 6V from G1 (power supply) board
Replace G1 Board to fix your tv problem.
Thanks.
Posted on Oct 16, 2010
55 inch Sony Wega rear projection tv...only stays powered on for a few minutes then goes blank, green light steadily burns and the picture is dark. Is it overheating? What do I need to do to fix this?
If its the model indicated here or one similar(kdf-55xs955) you may be seeing a lamp that is about to fail.
A lot of these just before lamp failure will get very dark and if bad enough the set will even shut off.
Mar 17, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
The sound and picture go off and the power light stays on then in a few sec. it comes back on.
This is symptom of weak lamp in Sony KDF-55XS955 tv, lamp has been reached to end of its working hours life and need to be replaced. Please note that lamp has not been dead/ broken yet but weak in result and causing problem.
Buy Sony original lamp and replace it in tv to solve this problem.
Hope these info will help you.
Thanks.
Jan 20, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a sony Vega 55" kdf-e55a20, It is 3 years old, and now the picture and sound fade away for 10-15 sec every hour or so and comes back! Anyone knows what the problem is?
Lamp is getting weak and TV shuts off and turns on itself because of weak lamp in TV that you see picture and sound fades away for some time until TV reboots.
Replace lamp in TV to solve this issue. Lamp replacement procedure is written in user manual and its an easy work.
Please buy Sony original lamp for your Tv safety.
Thanks.
Dec 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
No picture no sound
Thats great that TV is working fine. How about rating solution as 4 blue diamonds?
Thanks.
Mar 04, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blue cloud
That's OK, I been provided you technical info about TV problem.
Jan 31, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TURNS ON OK THEN SHUTS DOWN, GREEN LIGHT STAYS ON
Mine does the same thing try a new lamp I am with what I have read this is the best solution. I have had green screen two fans replaced and now this. The picture was great but with all the problems i would never but a sony product ever again for anyone out there you should tell them sony sucks and send them to this web site for clues. Good luck.
Dec 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
