Sony Handycam DCR-DVD105 DVD Camcorder Logo
Question about Sony Handycam DCR-DVD105 DVD Camcorder
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
Posted by shazna_998 on
Anonymous
    New Friend:
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Posted on Apr 22, 2011
I have a dcr-dvd105 handy cam I didn't see where to insert a memorie stick
According to the specs and docs on Sony's web site, the 105 doesn't take a memory stick. Some other models, like the 305, do but not this one.
2answers
Sony DCR SR 42E handy cam problem. Almost All of the available hard disc space is used up. now i want to copy all the video files from the Handy cam to my PC. i connect the Handy Cam to PC and select the...
Then the video data files are larger than 100 GB, simple as that. Video uses a lot of GB's, so that doesn't surprise me one bit. 100GB is a tiny amount of storage compared to modern machines, mine has 500 GB's, my Desktop has 1 TB.
Hi , My Sony Handy cam Model number is :DCR-DVD105. When i try to shoot any thing after i switch on my handy cam i get the error " DISC COVER OPEN,ACCIDENTLY TRUN ON POWER AGAIN" Every time i switch off...
for this u hv to reach the service center of sony cuz this problem is related to hardware may be the cover is not getting closed properly or any inner switch is broken etccccccccccccc
proper solution is service center
How to connect a macbook pro and a handycam DCR-DVD105.
If your cam has a firewire connection, you could plug it into the macbook and use iMovie to transfer the videos over. You can also get an external DVD drive to put those tiny DVDs into to transfer it over.
Sony HC-video 8
Do you have edit tools? If you do, first you need to find a way to convert analog video to digital video. A computer edit system can only understand video that has been converted to a digital file.
Your best solution might be to find a business locally that can convert Video 8 to DVD. Then you will be able to view your video.
2helpful
Cannot find sony usb cable to connect cam to pc
This problem has largely been answered by one of people posting the problem. Once the disk has been finalised in the camera remove it and insert it in the PC's DVD drive. If it "Autoruns" you will be asked what you want to do. If you have no third party video editing software on your machine select .....using Windows Movie Maker and "Import" the footage into that program. If the disk doesn't "Autorun" start WMM and import from your DVD drive (probably drive "D"). Use WMM's Help to find your way around.
5helpful
2answers
My sony dcr-dvd105 handycam camcorder all of a sudden shows only
There is 2 possibilities, either aperture of camera jammed and doesn't open or CCD Imager got defective in your Sony DCR-DVD105 camcorder.
Let me know if you have little experience of camera repair to guide you further.
Connecting Sony handycam with laptop
This procedure is explained in User Manual of DCR-HC30.
Importing from sony dcr dvd 100 to macbook
sell the camcorder and buy a different one, I did
Sony handycam dcr-dvd105
So far the only thing that I have found that works is Sony Vegas...
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
