Question about Panasonic KX-T7731 Corded Phone
How do use my caller id on my kx-t7731 telephone?
Posted by rbrown263 on
Carl Navarro
  • Panasonic Master
  • 2,460 Answers
Caller ID requires 3 things, service, hardware, and programming. The hardware is a CID card with a part number ending in 93, as in TA62493,82493,TD193 etc. Then system programming in the 900's turn it on for each CO line and the phone needs to be ringing to display CID when the phone rings.
Carl
Posted on Apr 21, 2011
How do i get caller id on main phone line
Do you have caller ID service from your phone co.?
Jan 22, 2015 | Panasonic KX-T7731 Corded Phone
The caller id is working but how to look back the last caller id number(or caller id log) on the KX-T7731, i am using it with the KX-TA824 system.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
Carl
Sep 08, 2011 | Panasonic KX-T7731 Corded Phone
Panasonic KX-TGA101S Cordless bought from US not working in Chennai Telephones ,BSN L(India). Can I have the name of Converter which help it work in compatable frequency for caller ID Thanks Ravindran P
There isn't any converter available. The technology used for caller ID is different and the telephone was made for US use. There's no way to change the telephone to make it compatible. You will need to either get a new telephone made for your country, or find an external caller ID display unit.
Jun 26, 2011 | Panasonic KX-TGA101S Cordless Handset
We have Panasonic KX-T7731 telephones in our office. we have three incoming lines and approx. 7 extensions. the phone co has assured me they've turned on caller id capabilities for all three lines but...
A 3x7 system with 7731 phones tends to show that you have a TA-624/824 series system. CID is delivered to the phones via a xxx93 card and programming. In a 624 it connects to the main board via a ribbon cable and is installed in the system cover. The 82493 cards plug into slots on the main board. Once, or if, the card is installed, it needs to be turned on via programming. At the very minimum, program 900 in system programming turns it on and there are other parameters that you can adjust in the 900's.
Carl
Mar 15, 2011 | Panasonic KX-T7731 Corded Phone
Is the KX-T7731 caller ID equipped?
The CID comes from a card with a part number ending in 93 as in 62493, 82493, 84893, etc. That and programming will display CID to Panasonic system display phones.
Carl
Feb 22, 2011 | Panasonic KX-T7731 Corded Phone
My kx-t7731 does not have an enter button.I can see caller id info when the call is incoming but can not recall data afterward.Is it possible to scroll thru caller id info? Is incoming caller id info...
Did you program the 2 buttons for CID-S and CID-I?
I can tell you how to do it, but it won't mean too much if you don't have the other programming done.
Try storing 96 and 97 under a couple of buttons.
Carl
Dec 17, 2010 | Panasonic KX-T7731 Corded Phone
My caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Dec 04, 2009 | Panasonic KX-T7731 Corded Phone
Caller ID display on Panasonic on KX-T7731 telephone set
Pick 2 buttons on the left side keystrip and label them CID-Indication and CID-Selection Then press PROGRAM press the button and dial 96 STORE for the first and 97 STORE for the second. When a call comes in, the Selection button will toggle between the name and the number and if yuu're looking at missed calls, the date and time of the call. When you miss a call, the Indication button will light and you press it to view the Names of missed calls.
Carl
Carl
Oct 24, 2008 | Panasonic KX-TA824PK Phone
How do I view caller ID?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
Sep 17, 2007 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7731 Corded Phone Logo
939 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
