I'm assuming that this laptop is using Windows, and that the password is to an account on Windows.
At the login screen, press Ctrl+Alt+Del twice, and another login screen asking for a username and password should appear. In this box, put "Administrator" for the password, and either insert absolutely nothing, or "Administrator" for the password. I don't remember which works correctly, but one of the two will.
Hi,yes there is but you'll have to open the system up,if you have no prior I.T expertise I'd suggest you take to a qualified Technician,but if you do here is how:First remove the Battery,then uncouple the system taking of where each of the screws go to then locate the CMOS battery(small battery Lithium Ion mostly in the shape of a cent or smaller),it may be underneath the keyboard or just behind once the external cover is open.unplug it from the system for about an hour or two reconnect it,couple the system and boot,go to Bios,reset Date and Time and save,then exit.
Water might have had damaged the keyboard.
Solution, get a new keyboard and replace it....or
get a USA regular desktop keyboard, plug it into one USA connectors, and use it.
It will work too
Please don't forget to rate if this answer helps you.
Go to: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?ct=SB&soid=108503&ref=EV
Drill down to your password reset scenario. This is for all Toshiba laptops. If this helps you, and you wouldn't mind, please take the time to rate my response to you.
Now, that is a tough one. Only way to unlock the hard drive is to have the original password. You will not even be able to access it retrieve any data you want to save.
Thinking you are in the market for a new hard drive and a complete reload of the system.
Hello:
i have problem portege ,when i do on it, always password show,but i have not not any
before password, any one knows how reset the bios ,
my e-mail: [email protected]
more details
