Foxconn 760GXK8MC-RS Motherboard Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just a beep all the time as button press to switch on G27MC K52H
Anonymous
Level 3:
Guru:
  • Master 433 Answers
  • Posted on Apr 21, 2011
Anonymous
Master
Level 3:
Guru:
Answers
433
Questions
Helped
87941
Points
1320
If it work but you hear a beep try another kayboard or take the mouse and KB off and swich on the pc if no beep that mean KB or mouse is bad change ,
if the pc not work that mean aproblem with vga card or ram
if you see that is helpful plz don't forget to vote me
best regards
3helpful
2answers
How to Fix Nissan Elgrand sunroof stuck with lock light on?
press the lock button 4 times quickly after you turn the ignition on. it will go into a beeping mode where you can now move the sunroof in small stages with the switches. set it to the normal closed position and now hold both switches in the back position for a second (or perhaps click the lock button 4 times again)
My hyundai i10 wont lock or unlock when using the press button on the key
Hyundai Grand i 10 Central lock module resetting process (2014 Model) Step 1 Enter car and close all doors. Step 2 Kept Fob key in hand Step 3 Repeat the below process 5 times 1 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 2 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 3 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 4 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 5 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch End After head a small beep from central lock module stop the process ( Beep sound is the Success Signal)
1helpful
Hi i have a 96 corsa with a grundig car 200 radio i have the code but dont no how to install the code?
Switch the ignition key ON
Press and hold AS button and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
3helpful
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
1helpful
I hav the code ect (Blaupunkt 300 ina astra van), now need to know how to install / reset radio
Press and hold AS button * and the ON button at the same time
PS3 will not switch to HDMI cable. 1) Tried holding power button. Will not beep 3 times. Just shuts off. 2) Tried using both cables and changing display settings to hdmi.
try holding poew buton again let it beep 3 times
then hold it a second time and it would beep once solid beep and then listen for two short beeps then release the power button you will see a screen marked connect controller with usb and press ps button to continue you are now in service mode then just restore default settings and you should be up in hdmi
2answers
Need a code for my blaupunkt car 300 E radio (GM0300X9302038)
Try code 8751
BASIC INSTRUCTIONS TO ENTER A BLAUPUNKT RADIO CODE
Press and hold
Press  Button
3helpful
Operating instructions for blaupunkt 300 in car radio cassette ,got the code but dont know how to punch it in to the radio
ENTER A BLAUPUNKT CAR300 RADIO CODE
Press and hold
Press  Button
3helpful
It is beeping "Error" with 5 beeps
5 beep error means that the waste ink tank is full. You can reset the counter to make it print by doing the following: You have to be exact. If you make a mistake in any of it, just go back to the beginning and start it all over.
1.Unplug the power cord from the printer
2.Hold down BOTH the POWER and RESUME button at the same time and then plug the power cord back in. Keep holding down the buttons until the printer finishes its powering up noises.
3.After the printer is quiet, release the POWER and RESUME buttons. Then hold down the RESUME and CARTRIDGE buttons at the same time with one hand, and press the POWER button with the other. KEEP HOLDING DOWN the RESUME and CARTRIDGE buttons until you hear 2 beeps. They will come quickly together and one beep will be longer than the other. Listen carefully, as they are not very loud.
4. Once you hear the 2 beeps, release both buttons.
5. After both buttons have been released, then press the CARTRIDGE button 15 times. You will hear a beep each time it's pressed.
6. After you finish pressing the cartridge button 15 times, then press the RESUME button one time. The printer will beep and shut off.
7. Turn the printer back on by pressing the POWER button. The printer will work fine now. The waste ink will have been reset to 50% full.
I want to disconnect the beep sound when I press record
From the manual:
"When [BEEP SOUND] on the [INITIAL] Sub-Menu on
the [TAPE RECORDING MENU] is set to [ON],
confirmation/alarm beeps are issued as follows.
1 Beep
• When you start recording
• When you switch the [OFF/ON] Switch from [OFF] to
[ON]
2 Beeps
• When you pause recording
2 Beeps 4 times
• If you perform a wrong operation before or during
recording."
Top Foxconn Computers & Internet Experts
Jose Ramirez
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
