Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
Posted on Apr 21, 2011
Nov 27, 2016 | Heating & Cooling
Jan 30, 2014 | Heating & Cooling
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Nov 25, 2013 | Heating & Cooling
Nov 08, 2013 | Honeywell Programmable Thermostat Heater
Oct 23, 2013 | Honeywell RTH8580WF WiFi Thermostat
Jan 25, 2013 | Honeywell Programmable Thermostat Heater
Sep 15, 2011 | Heating & Cooling
Nov 13, 2008 | Heating & Cooling
512 people viewed this question
