Question about Acme 5001 Supreme Juicerator Juice Extractor
I have an acme juicerator 6001 model and I was just juicing... i put vegetables in before it was quite warmed up and it looks like something happened to the motor. Is there a way to fix this?
Posted by jacquelinezu on
JOHN REILLY
    Champion:
  • 356 Answers
You may have tripped the reset button on the bottom of the juicer, just push
it back in. They really don't have to warm up, just give it a few seconds to reach
speed.
Posted on Apr 26, 2011
Where can I get the filters?
Hi Rue,
Here is another from Amazon to crosscheck Acme Replacement Juicer Filter Liners for Model 6001 or 5001 200 Pack .
Here is another source of 600 filters for a modest price. Acme Juicer Juicers at Discount Prices
Jul 27, 2014 | Acme 6001 Juice Extractor
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
I bought a used Acme Juicer 6001 and when it starts working it's ok, but after 1 or 2 minutes, it starts vibrating and goes like crazy. I only put shopped vegetables, like cucumbers, apples, celery, and...
Just the opposite. The only way I get by the vibration is with an old worn blade which
I sharpen with a drill using a small bit. Installed a new blade, once, and the juicer took
off on me. Even the pro's have trouble with the vibration issue. If trouble persists, try
a pulp ejecting type.
Apr 22, 2011 | Acme 6001 Juice Extractor
Model 6001, when I used it to make orange juice, it shook so much the top lid became loose. Why?
Not designed to juice oranges, but if you must, feed it real slow. Your juicer went out of
balance that's why the extreme vibration.
Apr 04, 2011 | Acme 6001 Juice Extractor
I am looking for parts for the Acme 6001 Juice
Just google Acme juicer parts. The new lids are a tight fit and
have to be filed down if you're handy.
May 11, 2010 | Acme 6001 Juice Extractor
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
I need to replace the base rubber bottom on my acme 6001 juicer. Where can I purchase one?
It's called a foot ring. Just google Acme juicer parts or contact
Waring at 1 800 492 7464.
Nov 08, 2009 | Acme 6001 Juice Extractor
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Acme 5001 Supreme Juicerator Juice Extractor Logo
251 people viewed this question
Top Acme Juicers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Acme Juicer Expert? Answer questions, earn points and help others
