Question about Cell Phones
II opened the box and hooked up the power and turned the pad on and when it started, the time and everything appear along with nine dots. The screen seems to be locked. Please help!
Posted by sam thacker on
Tom Carson
  • 3,083 Answers
The best thing you can do is take the phone into your provider. It might have a firmware problem, and in that case they might be able to flash it or advise you on the course of action to take. They can probably verify if the phone is good or bad, so that they can fix it, or you can return it.
Good luck, and hope this helps.
Posted on Apr 21, 2011
What part do I need to replace
Hello. What you are describing is a failing component on the power supply. Some part is working momentarily and then heats up and fails. Replace the power supply and you will likely fix the plotter. Power supplies can be ordered from: 0950 2623R HP Designjet 700 750C 755CM Power Supply
Jul 20, 2015 | HP DesignJet 750c plus InkJet Printer
I locked my computer with a password and now I cannot remember the password. How do I unlock my computer?
  • 1Hit "Control," "Alt" and "Delete" on your keyboard all at the same time and hold them for a few seconds. Select "Restart" from the list of options presented in the Task Manager. If you cannot get to the task manager using this method, manually shut down your computer by pressing and holding the power button. Wait about 30 seconds before turning the computer back on.
  • 2Wait for the computer to get to the Windows logo then press and hold "Control," "Alt" and "Delete." The classic login box will appear. Type "Administrator" in the dialogue box marked "User" and leave the password box empty. Click "Sign in" or hit "Enter" and wait for Windows to load the administrator profile.
  • Click the "Start" button on the bottom-left corner of your screen. Scroll through the list of programs until you find "Control Panel" and open it.
  • 4Locate the "User Accounts" tool. In the "User Accounts" window, select the password tab. Locate the account that you wish to reset the password for and select the text box with the black dots in it. Delete these dots and enter the password that you wish to use. Re-enter the new password in the "Confirm New Password" area. Click "Apply."
  • 5Close all of the open windows. Then, click your "Start" menu and select "Restart." Wait for Windows to restart and this time allow it to boot up normally. Enter the new password into the "Password" dialogue box and hit "Enter."
  • Source: http://www.ehow.com/how_6066989_troubleshooting_-unlock-computer.html
    Feb 25, 2012 | HP Computers & Internet
    My ps3 isn't working. It turns on but it dosen't go to that main screen where you can choose the user. i have had it since last christmas. but i don't think that's a long time. can i do...
    Do you just have a blank black screen once powered on? If you hook up the controller with the usb link cable, do the lights on the controller flash all four or is the 1 solid? If they are flashing, then you have what is commonly known as the Green Light of Death. It's when everything appears normal but no picture. If you have no flashing red lights on the controller, please post. MikesPS3repair(dot)com.
    Sep 22, 2011 | Sony Playstation 3 (PS3) Console
    There is a code F-1 appears on the screen along with the beep sound
    F1 means defective touch pad or ERC. Turn off the power to the range. Get to the ERC. If the pad and the ERC are incorporated, replace it. If not disconnect the touch pad ribbon from the ERC. Make sure there are not loose wires. Assemble the control panel back. Turn the power on. If F1 comes back - replace the ERC. If not -replace the touch pad. Good luck.
    Oct 28, 2009 | Magic Chef Ovens
    Acer monitor AL1916W
    start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
    Aug 26, 2008 | Gateway FPD2275W LCD Monitor
    Screen black after big storm...
    The set has sound and no picture.If you the SSB could be the issue but the tiny red dots on a black screen will need the panle replaced also. There is a way troble shooting can be done to determine if you will need the SSB or the SSB and the panel.
    May 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
    Psp
    you prolly need a new lcd. go to ebay or google and buy a new lcd or a lcd+backlight combo which will run about 60.00 open the psp and replace the lcd and the issue will be solved.
    May 17, 2008 | Sony PlayStation Portable (PSP) Console
    Screen goes black and turns off
    sounds like something is over heating.
    i would check convergence ic
    http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
    http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    Sep 28, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
    Thin vertical line
    What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
    Jan 21, 2007 | Mitsubishi CS-35405 TV
    Cell Phones Logo
    Top Cell Phones Experts
    ADMIN Canada
    ADMIN Canada
    Are you a Cell Phone Expert? Answer questions, earn points and help others
