Question about Dell Dimension 2400 PC Desktop
: Auto detect (digital input) self test feature check keeps dancing across the screen, if I push one of the monitor buttons then 2: analog input self test feature check keeps dancing across the screen, if I push that monitor button again then 3:Digital input pops up. just wondering how to get rid of this so i can use the monitor again.
Posted by pacecarman on
1 Related Answer
rommelalilin
Rommel Alilin
  • 2178 Answers
SOURCE: Dell,1: Auto detect (digital input)
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Posted on Nov 04, 2010
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
HDMI to VGA
You need a video format converter to connect in between.
Apr 30, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
The screen goes black whle I'm working and I have to push the monitor button and when it comes back, it says" auto detect analog input
go to power options in control panel and check if you have the option turned on to "turn off the screen after x minues of inactivity"
Jun 10, 2009 | Dell Inspiron 530 Desktop Computer
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Flat Panel Monitor: 1907FPt
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Aug 18, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
519 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
