Everything should be setup from the BIOS screen. Here is a link to the manual for this board. This should give you all the information you need. http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/MicroStar/ms6547/MS6547_u.pdf
Hope this helps... Dale
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
