Question about Sharp AR-168D Copier
I have a Sharp ar168d. The unit has had the triangle shaped warning light blinking. I talked to a service man and he said as long as it is still working don't worry about it. Now is has stopped. Tryed to print an address on a envelope, looked like it tried to print over itself. tried a second time, same thing, but it made a grinding sort of noise and got a L1 00 code. Wanted to see inside the unit to see if I could see source of noise so pulled all the covers, toner cartridge, then I took out the Fusing section to see into the machine better. Plugged unit in and clicked on button, got H2 00 code so reinstalled Fusing section. Restarted unit, still got H2 00 code. What do i do next? Tried to enter the code to get into the serviceman, but the unit just beeps when I press the buttons. Help!!! Dave
  • Anonymous Apr 20, 2011
    I had reinstalled the Fusing section. But now, how do I get the keys to do anything but beep? I don't see anything on the page for clearing the H2 00. Thanks Dave
    I sent a reply. Are you done helping? I already knew the answers you gave me. I want you to be specific on how do I get rid of the H2 00 code!! Thanks Dave
Jose Cada
  • 3,530 Answers
Welcome to Fixya
H2-00 means Thermistor open - Open upper heater thermistor or the fusing unit is not installed when the door is closed.
L1-00 Mirror feed problem - make sure the mirror lock is not on or remove
Please click here for the complete list of error code of your printer and how to reset the printer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Apr 20, 2011
Benjamin Jr Singson
    Genius:
  • 1,570 Answers
H2 00 code it thermistor is open. Just close it or inspect this section.
From the manual:
H2 00 Content Thermistor open detection
Details Thermistor open detection
Fusing unit not installed
Cause Thermistor defect
Control PWB failure
Fusing section connector contact failure
Check
and
remedy
Check the harness and the connector of
the thermistor and the MCU.
Clear the display of self-diagnostics with
SIM 14.
Remarks Thermistor open
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on Apr 21, 2011
  • Benjamin Jr Singson Apr 21, 2011
After replacing the toner catridge in Sharp MX-B200 the toner lit light keep showing, how do i remove the showing lit light
The toner light is in the shape of a triangle. If your light is in the shape of a circle you need a developer change. Technician required to do this.
Aug 13, 2017 | Sharp Office Equipment & Supplies
SHARP AR-5520 RED TRIANGLE LIGHT BLINKING HOW TO SLOVE THIS PROBLEM?
If the triangle of dots points upward it needs toner, if the triangle points down the machines waste toner needs to be emptied out.
Apr 27, 2017 | Sharp Office Equipment & Supplies
We no longer have our manual. The Little man is lit up and also the dotted circles to the right of the triangle. What does it mean?
the little man means time for service, that is replace the drum and toner developer units,
the maint. man has to be reset by aservice tech, you might try the sharp support site for the reset instructions .
good luck ,tinyman
Jul 19, 2011 | Sharp AR-153E Copier
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR168D not printing
Look above the shelf where copies come out. If you see a disk about 1.5 to 2" across , it may have been bumped into the "locked" position.
Either turn it 90 degrees or take it out & throw it away.
Oct 02, 2009 | Sharp AR-168D Copier
Unit powers up, but will not copy, and the light in the shape of a triangle is blinking
mos the toner light come on is just out of tonert likely is out of toner is it runs for ever and doent come to ready and finely
Jul 07, 2009 | Sharp AR 201 Copier
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
Sharp AR-168D Copier Logo
314 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
