What do you mean when you say limited service? if you have a low signal, you may be in an area where there is poor signal reception. try to contact your service provider to check if there is an ongoing maintenance in your area
if your problem is no incoming and or outgoing calls and texts, make sure that the barring is deactivated on your phone. to check, go to the settings of your phone, call settings, call barring, deactivate all. you have to call your service provider also if all your services are active on the account.
be sure that you are not covering the internal antenna when you make calls
try to remove the battery and sim and after a few seconds, put the sim back and turn the phone on, check if the services are ok.
It says Limited Service means it locked to network,Get the Unlock code at here http://www.theunlockarena.com/supported-phones/rs13wp7/
and Unlock it.
