SOURCE: Crosley traveler turntable noise
Hello attaboy. You may need to check you ac cord if the noise is in turntable, radio, & cassettte mod. If it has a 3 prong plug than you are missing a GND connection, in the cord or inside the unit. If it has a 2 prong plug than take it back or open it up and replace filter capacitors or bridge rectifiers in units power supply.
SOURCE: Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
SOURCE: Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
SOURCE: My Crosley combination turntable/CD/cassette/AM &
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
