Cell Phones Logo
Posted on Apr 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bluetooth is not working and battery problem please solve my problem
Anonymous
Level 2:
Novelist:
  • Expert 81 Answers
  • Posted on Apr 20, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
81
Questions
0
Helped
11807
Points
242
Hi there!
If you're having a problem with bluetooth then ill be advising you to powercycle your phone and you can do that by removing the battery on your phone while the phone is on.After that reinsert the battery and turn on the phone again and try turn on your bluetooth again.Kindly check as well if your phone is fully charged because bluetooth will not work that good if the battery on your phone is not fully charged.Kindly check as well if the device your pairing with through bluetooth is compatible with your phone because there are devices that are not compatible with each other.
If the battery is the problem then try doing the rebooting or powercycle process of the phone.If its still not turning on then kindly charge the battery for a maximum of 4 hrs.Please check if the battery is holding a charge.If it still not working after doing that then there might be a problem with the battery.Kindly replace the battery so that you can use your phone.
Thank you!
Bluetooth can not be conected by others
Please check the bluetooth settings that its turned on and not hidden mode(it should be "shown to all"). If that doesn't solve your problem then switch off the bluetooth, turn off the phone and remove the battery. Then after 2 min place the battery and switch on the phone and bluetooth. This should definately solve your problem.
Please rate the answer. Thanks.
Unable to perform bluetooth operation
What we call the interoperability can be simply the possibility for you to retreive the battery of the phone during a minute and put it on again.
The aleatory effect in term of interaction sometimes can cause troubles.
1helpful
2answers
Bluetooth
Try a copy of Bluesoliel it has far more bluetooth functionality
1helpful
Bluetooth activate error
HI,
Please pair the device with the phone? if not then read the manual of the bluetooth and pair them first.Also try turning the cell off & removing the battery and then turn oin again to see if the issue is solved.
Apple wireless mouse no longer connects
please remove the battery and check the mouse with saperate good battery also.update the mac os x with the latest avilable update.and update the bluetooth drive for mac.the issue will get solve
238helpful
18answers
Unable to perform bluetooth operation!how can i solve this problem???help me plz!
2helpful
7answers
Bluetooth is not working
I KNOW HOW TO CHARGE YOUR BATTERY IF YOUR PHONE CAN'T!
.... n_n ....
Nov 18, 2007 • Nokia 6600
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
