SOURCE: I can not connect 2 the internet on my 7" netbook
dude please make another post with the following info ,
make of the router , do u have static or dynamic ip, how is the connection setup done ...i mean how does it look like ?
SOURCE: sylvania 7 inch netbook isnt
1.Go to the run option, type in services.msc
2. Click on wireless zero configuration, click stop and start..if its on start, just on start.
3. Check your network and internet connect, or network connection in the control. see can you find the wirless network.
4. Make sure you have the ssid displaying in your router.
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
