Question about Sony Televison & Video
Trinitron sony model KV-27FV17 tv will not come on it is in standby mode
Posted by swilliams3rd on
Sathya Vijaya Sarathi Babu
    Novelist:
  • 123 Answers
Usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ............... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, [email protected] ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact sony service centre.........
Posted on Apr 22, 2011
We have a sony trinitron tv that after using sleep mode turns itself back on after a couple hours. any idea how to fix this?
Get into its menu, come over to timer settings. Set the timer to 0:00. The set never get Off after that. Now, it might be set to 2:00; I assume. You should have its remote control to set this, as some Sony Trinitron models will not have a Menu button at its front panel control; to enter into its menu option.
Electrohelponline
Oct 04, 2014 | Sony FD Trinitron WEGA KV-27FV17 27" TV
No sound at all on my trinitron sony
Get into the blogsite name Electro-help for details.
Apr 28, 2012 | Sony FD Trinitron WEGA KV-27FV17 27" TV
Sony Trinitron TV
read the answer on this page really helpfull
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Apr 01, 2010 | Sony FD Trinitron WEGA KV-27FV17 27" TV
KV-27FV17 No Signal When we turn it on it shows No signal...Help
check cable/ antenna first,if everything okay, the tuner assembly might be ta fault.
Aug 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Oct 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron kv-27fv17
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby, this means there is a component inside your TV set, in the main power supply or the sweep power supply that is not letting the TV set's power supply regulate properly. I'm sorry to say, there is no quick fix for this and is going to need to be diagnoised by a trained tech. Good Luck
Mar 19, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
109 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
