Question about Panasonic ET-RM100 Remote Control
I just got a Panasonic CT-2733HSF television that is stuck in hotel mode. How do I get it out of hotel mode? I was given instructions to press action volume up and then action volume down and to do this within the 1st 3 seconds of turning it on. I was told that I would see the word "OFF" in red letters in the bottom corner of the screen. This is not working. All this function does is bring up the tv menu with the following options: closed caption settings, tv/video setting, parental control setting, mono stereo setting. I have the remote that goes with it and have I have spoken with my cable company that told me I have to get it out of hotel mode to be able to access channel 3. At this time, the lowest channel is channel 4. If I try channel down after 4, it goes to "Input:video 3" and then Input: Video 2 & Video 1. What am I doing wrong?
2 Suggested Answers
Mick
  • 325 Answers
SOURCE: Need a clone box for multiple Panasonic ct 2522 he televisions
You can get your Panasonic Tv out of hotel mode with the Regular remote control you got with them.
Please follow the steps below.
Press and hold the V/- button on the tv itself.
while you are holding this button down, with the Panasonic remote you got with them press the AV button 3 times.
This will bring up a hidden Installer Menu this is where you can take off the HOTEL MODE. and set up your owe setting.
While you are in this mode, be very care you are not switching things off that you are not sure what they are. as this may put a spanner in the works
Hope you get this all sorted out.
Little Dish Fitter
Please leave a thumbs up if this sorts you out....
Posted on Sep 26, 2009
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: The owner of the hotel
I apologise in advance if I repeat anything you have already been told, but I am only able to see your comments and not the solutions written by other experts.
3 things come to my attention:
1. You should not need a clone box to switch the TV to "NORMAL" mode
2. The availabilty of parental lock in the menu does not indicate that the TV is in normal mode. There is a parental lock setting in both the hotel and normal mode menus.
3. The main menu is accessed by pressing the "ACTION" button. If you are getting the "SETUP" menu when you press the action button, this would confirm that you are still in "HOTEL" mode.
The NORMAL mode menus have graphical icons. The HOTEL mode menu is simply a text menu in list format. Therefore, it is simple to determine which mode you are in after pressing the ACTION button.
Obviously, knowing this doesn't solve your problem. You should be able to switch to normal mode using the buttons on the front panel of the TV (not the remote) as follows:
1. Switch the TV on
2. Press and hold both the "ACTION" button and the "VOL >" button for about 1 second.
3. Release both buttons and, within 1 second, press and hold both the "ACTION" button and the "CH ^" (channel up) buttons for about 1 second.
"OFF" should flash in red in the bottom corner of the screen, indicating that you are in "NORMAL" mode. You can switch back to "HOTEL" mode by repeating the steps above. In this instance "ON" will flash in red in the bottom corner of the screen.
Please note: it can be quite difficult to co-ordinate the button presses and timings correctly, so you may need to try several times. It may also work if you continue to hold the "ACTION" button, then release only the "VOL >" button and then press the "CH ^" button.
If you still cannot switch to normal mode, please make sure each of the buttons on the front of the TV required for switching modes are working correctly. Make sure the "ACTION" button opens the menu, the "VOL >" button increases the volume and the "CH ^" button changes the channel up by one position. If one of the buttons on the front of the TV isn't working then try another TV.
If, having tried all of the above, you cannot return to normal mode, please post back for further assistance.
Regards,
BElectric
Posted on Jan 01, 2011
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Nov 28, 2015 | Sanyo Televison & Video
How do i get my panasonic th37pr9u out of hotel mode..i have a clone box for it and am not getting anywhere..i have tried a few things i found online but no remedy has worked..
To get it out of Hotel mode, you have to enter its service mode option. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the keyword "Hotel mode" & brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 14, 2015 | Panasonic Televison & Video
How to go to service mode in ct-g2978b Panasonic tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 08, 2015 | Panasonic Televison & Video
MY PANASONIC CT-36HL43G HAS A PROBLEM WITH THE VOLUME. IT ONLY SHOWS UP TO 63 ON THE SCREEN AND THAT ISN'T LOUD ENOUGH. ANY ANSWERS ?
Volume might be locked at "level 63". Refer its user manual to get details about how to unlock the volume. If the set is in Hotel mode, this might happen. If you wish to get out from Hotel mode to Normal mode [if it is so] you have to enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 25, 2014 | Televison & Video
My Panasonic CT 2521 HDB needs to be reprogramed
Reset it to its factory default, and then reune it. Refer its user manual for details.
May 07, 2012 | Panasonic CT-34WX54 34" TV
Can't exit hotel mode on Panasonic CT-2552HE
you will need the panasonic remote..
hold down the V/- button on the television. Then press the AV button 3 times on the Panasonic Remote. This will bring up the hidden menu for you.
hope this helps
Cheers
Little Dish Fitter.
Aug 21, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
Little Dish Fitter
Jun 29, 2009 | Panasonic ET-RM100 Remote Control
Getting out of hotel mode
hi have crown tv modle number ctt20001 i think it is stuck in hotel mode
Feb 20, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Panasonic ET-RM100 Remote Control Logo
210 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
