Question about Nikon N90S 35mm SLR Camera
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
Posted by woolley101 on
htp4
    New Friend:
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
What does FEE mean? The camera won't take a - 1157b.gif src="/uploads/images/1157b.gif" alt="1157b.gif" class="h_mi" />
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doinWhat does FEE mean? The camera won't take a - 1157c.gifse also check the fWhat does FEE mean? The camera won't take a - 1157d.gif
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Posted on Apr 19, 2011
Where is serial number for Nikon N90s located
Nikon tells you all this stuff. You are dealing with the best camera in the world :>)
Where is my serial number Nikon Knowledgebase
May 06, 2016 | Nikon N90S 35mm SLR Camera
What does error 7 mean?
try a web search, you'll be surprised what you may find. just enter 'error 7 Nikon N90s'
May 17, 2014 | Nikon N90S 35mm SLR Camera
Nikon N65 won't take a picture
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Feb 13, 2013 | Nikon N65 35mm SLR Camera
I have an internal scratch on my n90s nikon camera
I believe you mean the focusing screen. While this is an interchangeable part on higher-end Nikon cameras, it's not on the N90s. Your local authorized Nikon repair center may be able to replace it, if they can get a spare.
Before repair, bear in mind that the focusing screen will not directly affect any of your pictures. Due to the very nature of a SLR, when you take a picture the mirror flips up next to the focusing screen to let the light from the lens through to the film, bypassing the focusing screen and the rest of the optical viewfinder system. If the scratch isn't very big then while annoying it won't affect camera operation. If the scratch is very large, on the other hand, it may affect the exposure metering and, of course, your viewing.
Apr 04, 2012 | Nikon N90S 35mm SLR Camera
On the Nikon N90s what does the flashing fEE mean?
It means that your lens is not set to the minimum aperture and your camera is either set to program mode or shutter priority. Also, it can mean that your flash is in an incorrect mode.
For any camera operating mode where the camera controls the aperture automatically, your lens must be set to the minimum aperture setting - which will usually be f/22. This aperture marking will be the one in orange.
IF your lens IS indeed set on f22 and you still see the fEE, then you may have mounted it incorrectly. Remove the lens and try to carefully remount it (with it set at f/22).
Let me know if you need further help or clarification.
Dec 13, 2010 | Nikon N90S 35mm SLR Camera
Can't take a picture
Set your aperture to the maximu f stop number, that means the minimum aperture, and your camera will work. Take out the lens and align the ring to set it to the minimum aperture. I shall paste a link down here so that you can refer in detai.
http://loeki.tv/log/archives/85-FEE-error-on-Nikon-DSLR-fixed.html
Dec 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon N90s /film 35mm slr. I haven't
If the switches and contacts are dirty that would do it. If that happens the cost of service may exced the cost of buying a used one.
Aug 24, 2009 | Nikon N90S 35mm SLR Camera
N90s -How do you attach the Film Pressure Plate to the film door?
Press down and slide one way or the other. It's generally held by two pins that slide into hole slots and lock in place
Jul 11, 2017 | Nikon N90S 35mm SLR Camera
Nikon N90S 35mm SLR Camera Logo
419 people viewed this question
Top Nikon Photography Experts
Ric Donato
Richard C Cohen
Richard C Cohen
JOHN TOPLISS
Are you a Nikon Photography Expert? Answer questions, earn points and help others
