Question about Whirlpool Dishwashers
My dishes are cloudy and all the glassware and pans are cloudy and striped with detergent. I have tried 2 times to use a dishwasher cleaner, yet the problem remains. Any solutions?
Posted by lin_richers on
Mike
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on May 16, 2011
D. Floyd Kolb
  • Whirlpool Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Apr 19, 2011
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
CLOUDY GLASSWARE
Cloudy glassware happens when your glasses are etched by the combination of your water and the dishwashing detergent you are using. Once the etching occurs, you can't really do anything about it. If you are not doing so, try using a rinse agent such as Jet-Dry. This will help prevent the etching/cloudiness.
I hope this helps. If so , please come back and rate my suggestion.
Jun 11, 2011 | Dishwashers
Glasses marked in dishwasher
This is etching caused by your water source and detergent.
Begin using a detergent brand called FINISH or ELECTROSAL
Also use the LEMISHINE product to clean the dishwasher internally.
If you can not find LEMISHINE,start your dishwasher normally and with NO dishes. Once it starts add 2 cups of WHITE vinegar to the wash tub and let the machine run a full cycle.
These steps should produce cleaner dishes and no etching.
It will not remove etching from existing glassware.
May 28, 2011 | Dishwashers
How did I get the film off my glassware? My glassware has a thick film that is very unappealing. I have to hand wash them. I use cascade detergent.
If you are not using a water softener use a rinse aid such as Jet Dry. This will help to eliminate scum on glassware. Use the solid form of Jet Dry. If you use a water softener you need to decrease the amount of detergent.
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Mar 12, 2011 | Whirlpool Dishwashers
My dishwasher has all of a sudden started leaving a cloudy residue on my dishes and I cannot even wash the water spots off of my glassware. I have not changed my dishwashing powder nor drying agent
heatman101
Feb 23, 2011 | Maytag Dishwasher
Our Maytag MDB9100AWB is 5 years old. Have had repairman out several times. Problem is a light cloudy scum on everything. He has replaced several items, has had us clean parts and fixtures, etc and even...
There are three typical causes of chronic cloudiness on glassware/dishes.
  1. The incoming water may be too hot. Make sure the water is at or below 140 degrees F.
  2. Test to see if cloudiness is removable by hand cleaning or soaking for 5 minutes in white vinegar. If it is removable, it's due to hard water. Use a good quality detergent, and match the amount of detergent used to the water hardness and use a rinse aid. (Some low quality detergents clean poorly and leave a film.)
  3. Glassware may be etched, due to too much detergent, too high water temperature, or pre-washing. Etching is not reversible, so it's important to correct the problem promptly.
Hopefully these hints will help you to home in on the problem.
Dec 27, 2010 | Maytag MDB9100A Dishwasher
Glassware keeps coming out cloudy and spotty. Have tried various products. I use jet dry hanging basket style. Only get glassware spotless by running without soap and using vinegar. I would like to use...
Use the detergent meant for dish washers. Fill the rinse aid dispenser as per the user guide.If the water quality is hard. Use softeners. If dish washer salt adding provision is provide fill the dispenser.
May 19, 2010 | Dishwashers
Cloudy film left on glassware *rinse aid cup
make sure b4 you start the machine run the water until it is hot then start the machine. let me know if it works by sending me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
Glassware is cloudy
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Nov 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag quiet series 300 dishes are ''cloudy''
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Mar 20, 2009 | Maytag 24 in. MDBH955AW Built-in...
Dishwashers Logo
214 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
