F5 - E1
Self clean latch will not lock
1. If door latched:
2. If door not latched:
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Good Morning, Sometimes an F5E1 will appear when the control board is faulty.. because it isn't properly driving the door latch circuit properly. If the door latch assembly is fully functional, we recommend sending in your oven control board to Fixyourboard.com for testing and/or repairs. Reach out to them at 512-355-1108 or [email protected] They also have replacement touchapads for this model oven if needed.
