You need to delete the upper and lower filters on the said registry entry.
{4D36E965-E325-11CE-BFC1-08002BE10318}1
You can read the instructions complete with screenshots from the link I added. Cheers!
Fix Windows 10 DVD CD ROM Error Windows cannot start this hardware device...
SOURCE: optiarc ad 7530a dvd rw drive
I have seen this problem many times. 99% of the time this will fix it for you. The first part of this fix is to backup the current registry just in case you need to go back.
Try this. I really think it will fix your problem :)
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Restart your Computer in order for the registry - fix to work.
SOURCE: my Optiarc DVD RW AD-7530B ATA Device did not recognize all cd...
Microsoft has released a fix for this issue.
Please visit this site and attempt the automated fix "FixMe" option. After this completes, restart your machine.
If this does not solve your problem, follow the instructions on the page to perform the fix manually.
http://support.microsoft.com/kb/314060
If this information was helpful to you, please take a moment to rate the solution. If you have any more questions please let us know.
SOURCE: I cannot use my Optiarc DVD RW AD-7530 ATA Device
don't worry frn, this is not your DVD's fault. it will happen due to the cd's speed, while recording to the CD's if you burn cd's or DVD in very high speed then some of the DVD's cann't support that why your dVD do. so be sure that you have the CDs that are coppied with less speed. or it will happen due to the dust in lens of DVD so use the lens clearner CD to clean the lens i hope that it will ok. byee
SOURCE: OPTIARC DVD RW AD -7530B ATA DEVICE NO FUNCIONA
From your description I understand that the DVD drive is not working and you have code 39 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
