Hello and Welcome!
The error 0xc18a0206 is mostly occurred in HP printers
To solve the error code 0xc18a0206, Follow the given steps
Error will automatically remove.
But if u face still this error then printer service required. In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
SOURCE: 0xc18a0206 error on hp photosmart printer
Fro our Fixya community:
Try holding down the OK, Cancel, Black, and Color buttons all at once. While holding them down, press the On button to power it off (You may need another person if you lack large, coordinated hands). Turn it back on while still holding the other buttons down. You will notice it turn itself off before "booting" fully. After it turns itself off, you can finally let go of those buttons and turn it back on normally. This will force a reset and system maintenance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
SOURCE: hp 3310 photosmart - ink system failure 0xc19a0013
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
If this doesn't work let me know.
SOURCE: I recieve Ink System failure
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
