SOURCE: IceCam on Mac OS 10.4.8
This is possibly the strangest reply ever - to my own question! But I have tried out several possibilities and discovered that: If you plug your IceCam into a USB-hub you will lose some signal; if at all possible, plug your cam -directly- into a USB-port on your computer. Much better/stronger signal!
SOURCE: Icecam set up/installation problems
Hello all, we supply Macally Icecams through our company and have done so for many years.
The camera works absolutely fine with Skype.
Unfortunately Skype do not make it easy for people to understand how, so we wrote a user friendly blog about it and it can be viewed here:
http://blogs.ebay.com/skinnywolf_online/entry/Webcams-for-Mac-Users-The-best-VoIP-Interfaces-t/_W0QQidZ189277018
Simply copy and paste the above link into your browser to find the easy set up procedure.
Hope this helps
SOURCE: problem with macally icecam
1. You can open only one video application at a time, therefore, you need to quit ALL the application first, then open the one application you want to use. such as YIM or Skype.
2. Please open the iceCam Monitor, go to Monitor tab, check the "Record Video" and select "Record Until MouseClick".
A new Save window will pop up, set up the filename and location and click SAVE button.
Once you click the mouse button, it will save the recorded video as QuickTime Movie clip format file on the selected location.
If you want a picture, you could run the video and pause it and make a screen shot to grab the picture from the video.
SOURCE: having trouble with Icecam 2 set up?
windows often has MSN runnin in some form in the background, this is usually not a problem, unless you are trying to use a different Chat app as MSN will grab your webcam :S
SOURCE: webcam trouble shooting
See section B. Yahoo in the info below.
Normal
0
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see and
talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set
it up as follows:
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
