Replace you ATX casing. the power switch of your ATX is not working..
Check to make sure it is not just a front panel power switch problem. You can disconnect the jumper wires from the switch at the motherboard and carefully use a screwdriver to short out the 2 pins in order to similate closing the power switch. If the machine starts up properly by that method, then you probably just need a new power switch.
Also try removing your CMOS battery and leaving it out overnight. While you are at it, you might as well replace it with a new one just in case it is dead or dying, then try booting up again.
Otherwise remove all the unecessary USB components, drives, and cards from your computer and try booting up with just the hard drive and the onboard video card installed. If the machine still wont even power up, then you have some kind of problem with your motherboard.
Try disconnecting and reconnecting all cable connectors from the power supply to the motherboard and double check all your jumper wire settings on the mobo.
Also try unlocking and removing the CPU and heatsink assembly together. Reseat the pins back down into the holder and lock it back down again. It is possible it is just a bad connection between the CPU pins and the socket.
There's not much left after that except a bad motherboard or CPU. Good excuse for an upgrade.
Thank you and good luck.
Have you try to check the power port of the laptop? Is the power port built-in to the motherboard? If not try to check the wire that's connected from the power port to the motherboard. =)
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA the leads from your ((motherboard to
your hard drive)) make sure they have a secure connection and are not
faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
