Question about Samsung DCS 12 Corded Phone
I have various incoming lines into my idcs28d switchboard - how do i program the switchboard to name each incoming line so that we can see the name allocated to each incoming line when the switchboard rings?
Posted by rowan532 on
Phone Systems
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
If you follow the the video I have posted you should be able to tag inbound DDIs, the phone used is the new 14 btn samsung handset, the soft buttons an a 12 btn handset are down the side but apart from that the softkeys are the same. go to http://www.abbeytelecom.com for more of these.
Posted on Jun 13, 2011
I dont get ringtone on incoming calls,only green light on line flashes.
go into your phone settings and go to ringtone check volume not turned down or been muted
Jul 15, 2017 | Miscellaneous
How can I change the direction of incoming calls to various extensions?
Just a guess but maybe changing the connections for the lines on the switchboard. This may also change their numbers though.
Apr 10, 2015 | Panasonic KX-DT333-B Digital Phone
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
Don't know how to transfer incomming calls, keep loosing someone
By pressing credle then dial the number to whom you want to do.
Sep 07, 2009 | Emerson Switchboard Deluxe Phone Line...
How do I change the display name on incoming line
You would have to go into program mode.
program 93-1 would do the trick.
Tony
Ameritel
732.477.7733
Jul 09, 2009 | Toshiba DKT-2020 Corded Phone
Unable to redirect incoming calls to a different number
Yes, Your system administrator will need to create a system reroute plan for you.
Mar 17, 2009 | Mitel 5220 IP Phone
Switchboard PABX purchase
If you need 8x30, you start with a minimum of TDA-100. It grows to 96 ports and you would start with 8 lines and 32 digital ports.
Your phones become KXT-7633's, not the 7731's. On this side of the pond, it costs about $20 more per phone, but you gain the use of 12 extra buttons, 3 line display, and more features.
Your Panasonic TDA/TDE dealer can guide you.
Carl
Jan 15, 2009 | Panasonic KX-T7730 Corded Phone
Incoming only line
a programmed incoming only button has a direct inward dial line assigned to it and would have to be removed in installer programming. its under your line appearances.
Sep 12, 2008 | NorStar M7324 Telephone
Noise in system
Probably in the module. Switch to different port on module and see if it clears the problem
Jun 17, 2008 | AT&T Partner 18 Phone (315805B)
Samsung DCS 12 Corded Phone Logo
103 people viewed this question
Top Samsung Lands Phones Experts
Dakshinamurthy...
Bruce Showalter
Lawrence Oravetz
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
