Question about Insignia IS-LCDTV32 32 in. Television
Insignia TV with built in DVD player
My 80 year old father has purchased a 32 inch Insignia TV with built in DVD player. He purchased it from Best Buy in Peoria, Illinois. He purchased in March of 08 and has had to take it in for repair because DVD player did not work. After they sent to Chicago for repair and having it for atleast 2 weeks
the DVD player still is not working. Best Buy refuses to try to get a new TV for him. He did not buy the extended warranty. He paid over $700.00 for this television to begin with. It obviously is a faulty TV. You would think the decent thing to do would be to replace his TV. He also has not received his reward certificates. I am very unhappy at that store and I will be sure to tell everyone I can BOYCOTT BEST BUY!
Posted by AuntSuzies on
5 Related Answers
Anonymous
SOURCE: TV won't turn on
if you get a service man to come out and look at the tv there are three capacitors at the top of the power supply that look like they are about to pop replace and the tv will wotk fine. they cost about two dollars each
Posted on Mar 23, 2007
Anonymous
  • 14 Answers
SOURCE: Insignia LCDTV 26
There are other places you can take monitors to get worked on. I believe just about any TV repair facility will also be able to repair LCD TV's as well. You may want to first try something else first however. Go buy yourself a UPS Battery Backup that has AVR (Automatic Voltage Regulation) built-in. I'd try doing that before paying someone to try and fix it. Besides, if that doesn't do the trick, then you can always take it back for a full refund.
Posted on Mar 02, 2008
Anonymous
  • 51 Answers
SOURCE: Insignia 32" remote does not work
If you have a cell phone with a camera on it, aim the remote at the camera and look at the screen on your phone. Press a button on the remote, and see if you can see the light blinking on the remote, on the cell phone screen. If you can, at least you know the remote's working.
If it is, check to see that there is nothing blocking the line-of-sight to the screen.
Finally, when all else fails, try a cheap universal remote. Go through the manual programming steps.
After that, the only solution is a faulty IR sensor in the unit itself. Bring it in to a repair depot....you should probably still be under warranty.
Posted on Jan 02, 2009
vinzen
Vince Albi
  • 217 Answers
SOURCE: Insignia 32 in Flat Screen
How is the input hooked up?.By cable? RGB HDMI? Check that the set is set to the right input.Check all connections first.Try a different input to see if you get Video.Good Luck.
Posted on Sep 07, 2009
John-INSG
John-INSG
  • 312 Answers
SOURCE: I have the same problem
Unfortunately your TV will need to be serviced. You may take the unit to Best Buy to arrange for repair.
Posted on Sep 25, 2009
Insignia 32 flat screen will not stay on. Power on and go right back out? What is the cause for this to happen?
Top 144 Complaints and Reviews about Insignia TV
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.5 - ‎80 votes My son purchased a 42" Insignia TV for me before he died. ... Bought 50 inch Insigniaand after 13 months screen starts going black but sound stays on. ... I was having problems with the Netflix app on my 42" Insignia smart TV, so I took the ...
Sep 23, 2015 | Insignia Televison & Video
I just bought a 32' LCD TV from best buy and it comes with a built in DVD player, it appears that somthing is jamed in the player. How do i know for sure and how can i get it out? (it says "disc in" but...
best advise is to take it back to best buy.these tvs have a two year warranty on them. i had one that stopped working and only had it two months. if best buy hassles you about the return. get in touch with a insignia rep they will get you taken care of.
Sep 16, 2010 | Insignia IS-LCDTV32 32 in. Television
I have a 42 in. insignia. It was purchased for our middle school and is hanging on the library wall. The problem is that there is no remote for the tv. It was a floor model. Our 70 year old librarian has...
You can purchase insignia remotes through eBay or Craigslist, or travel to Best Buy to see what options they have.
Here are some Insignia remote codes:
  • 10171
  • 11204
  • 11963
  • 12002
  • 10463
  • 10783
  • 11944
  • 11250
They are basically just LG televisions branded Insignia by Best Buy.
Feb 04, 2010 | Insignia IS-LCDTV32 32 in. Television
Used insignia 32 inch with DVD. want to reset
most manafactors codes are 1234 or 0000 or 5555 or 8888 you might have to put extra didget on EG 12345 -00000 - 55555 -88888 but if you changed it sorry dont know
Nov 10, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
My Insignia 26
Check your warrenty to see if the tv is still covered. If not, I would just buy another dvd player and attach it to the tv, it would be cheaper then repearing the tv.
Jun 02, 2009 | Insignia LCDTV26 26 in. Television
Two DVD's stuck in Toshiba Regza with built-in DVD player
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Jun 01, 2009 | Toshiba REGZA 47HL167 TV
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Dec 03, 2007 | Insignia LCDTV26 26 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
277 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
