You will need first to configure the antenna sources where you want to program channels. and then you can add channel through your remote control. to add channels in the channel memory, first press MENU and open the set up menu and then highlight installation and press enter. a new set of installation menu icons will appear on the screen. open the terrestrial menu highlight channel add, and then press enter. the list of channel program from the antenna source that you select will appear on the screen. to add now a channels to the channel memory, highlight unchecked box next to the channel number you want to add, and then press enter to check the box.to save new settings highlight done and press enter.
SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
SOURCE: I have a toshiba regza model 42AV500A which when I
I Have a tosshiba regza 42" . But when we try to go onto atv it will not let me as its not highlighted and can only get digital. the reason i want atv is to get a spare channel to bring sky through Thanks
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
• You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
• If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
• If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
• To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
• Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
