Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine won't recognize the hard driver. (WDH1U5000N 500 GB) USB works but it doesnt appears the icon on ''my PC'' so i cant open it and of course i cant use it
Carlo Barzo
Level 3:
  • Master 530 Answers
  • Posted on May 14, 2015
Carlo Barzo
Master
Level 3:
Answers
530
Questions
0
Helped
128315
Points
1766
Good day, this video will guide you and teach on how to fix your problem with WD 50GB. Have a nice day!
5 Related Answers
Anonymous
  • Posted on Nov 06, 2008
SOURCE: XP doesn't recognize my external 500 GB WD My book essential edition hard drive
I had the same problem some have posted about. I had a lot of data on my drive and then one day it didn't show up in "My Computer" anymore. I had to assign a separate drive letter to the external drive.
Plug in the drive.
Right click on "My Computer"
Click on "Manage
Click on "Disk Management"
On the bottom half of the right side you should find "My Book" assigned to a disk number.
Right click on "My Book"
Click "Change Drive Letter and Paths"
Click Change
Select a new drive letter and hit OK
Hope this helps some people out.
Anonymous
  • Posted on Dec 13, 2008
SOURCE: My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive
Well i got a simple 320 gb external hard drive, and since the first month i had problems, i solve the recovery issue by opening the hard drive, and find it out, the inside was broken, and it got unplugged. so plugged it back and got my info. if your data its more important than 200dlls or less break the thing open, because if you claim the warranty they are not responsible for your information.
Anonymous
  • Posted on Dec 14, 2008
I had a similar problem with a WDelements 250gig.
I found that if i plugged it directly into the computer USB and NOT through the USB i had attached to the computer it rectified the problem..
not sure if this will apply to you, but i thought id share.
Anonymous
  • 146 Answers
  • Posted on Dec 27, 2008
SOURCE: HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Anonymous
  • Posted on Apr 04, 2009
SOURCE: un recognized drive
what you should do is search for a driver for it so put the name of the usb then driver in a search engine and download and install a driver this should make the computer able to recognise the usb's software
Wd 500gb hard drive is not shown any power it was working fine suddenly when i try to connect to my laptop nothing appearing. plz advice
Good day, this video tutorial will help you to recognize your WD 500GB. Just follow instruction and your problem will gonna fix.
Left my wd book elite unplugged awhile. now computer won't recognize it. plugged in same way and in same position on my desk
Try plugging the usb cable directly to a usb port on your computer and not through a usb hub. Also make sure the ac adapter for the Western Digital is getting power and the light on the drive is on. Also a recent update to your virus program could be blocking it( it happened to mine).
Thanks for using FixYa
Well i bought my first hard drive(WD) yesterday 10-25-10 and when i plug it into my mac power book G4, its not recognized. I went to utilities to try to format it. I see the hitachi drive and the Macintosh...
if you are trying to install through usb then check if the usb you are using is working try to connect a flash drive on the same usb and try of use the other HD on that usb and see if it gets detected if no then uninstall the usb drivers from device manager and restart the system and it will work and it will get instaled automatically
How do i use SATA to recover my data from my WD 500 gb mybook? you see my power source is working at all.
You dismantle the case and extract the hard disk. Then you take that disk and you put it in a desktop pc (you will need a SATA dat cable, a SATA power cable and 4 small screws tu secure the disk inside. Once it's installed just start the pc and open My Computer - the disk will be there, copy from it whatever you want.
My husband has the 500G WD external hard drive which has worked perfectly until yesterday. Now when he plugs it in, the computer doesn't recognize that anything has been plugged into the USB and it's not...
Try it on another computer to see if it is working. Sometimes the USB cable can fail, too, so if you have another USB cable that fits, try it.
If it still does not work, perhaps the drive has failed.
250 gb Hard drive not being recognized
try these two option:
1).start-my computer-right click-manage-device manager-action-scan for hardware changes-check on the usb if all 6 of them are working if not reinstal driver.
2)download this program ,instal it and update your drivers (usb) is free from here http://www.radarsync.com/
USB not recognized
you can download the driver from western digital's web site, you most likely had a surge on the drive when you first plugged it in and it swiped everything of of the drive.
Turns on but nothing else
I have been using this hard disk for about 6 months now. It stopped working. The power and the usb cable are connected. I use Windows Xp and it doesnt read it. And for some reason most of the time when i open 'my computer' and the hard disk usb cable is plugged in 'my computer' stops responding !! However the 'safely remove disk' icon comes on the task bar and i can remove it from there. But i cant read it from explorer. The light on the HD keeps blinking. It reads my friends HD and flash drive. Please help me.
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
