Question about HP Compaq Presario SR2150NX PC Desktop
I add a flat screen
It won't re boot at all,&leaves a message on screen......not formated device?
Posted by borisgump on
  • 5 more comments
  • Anonymous Feb 24, 2019
    Dude, I can very well relate to your problem, this happened to me as well. But from the help of essaypro writers, I came up with an easy solution. It is very detailed so you should ask them yourself.
  • Aftab Aati
    Aftab Aati Mar 23, 2019
    What is this all about? I'm not here to tell you about altomerge.com, but to do something that can help you a lot. It's going to be easy for you and for me for sure.
  • SABABA
    SABABA Apr 02, 2019
    https://www.timesofsilicon.com/how-many-...
    Take most out of your Hulu plan, know How many people can watch Hulu at once or simentanously and How many devices can you watch Hulu on at once.
  • Aftab Aati
    Aftab Aati Apr 19, 2019
    Numbers 6 Revolves around the laws of attraction, faithfulness and and harmony. This number is associated with dreamers and hard working individuals that have strong ambitions… meaning of master numbers in numerology
  • Aftab Aati
    Aftab Aati May 16, 2019
    Did you not see the work on ladyfortune.podbean.com/e/folge-11-bitcoin-besigt-gambling-welt/? People are talking a lot about it. I don’t get what is in this article to that about.
  • Anonymous May 21, 2019
    2007 built RELIC grade PC now 13 year old.
    the HDD is bad. end story.
    new HDD + new OS and now it boots.
    or the RTC coin cell went bad.
    the COin cell bad makes the BIOS GO NUTS.
    and with BIOS nuts can not boot any thing at all or for sure not reliably,
    learn that this battery lasts 7 years max (spec) life. time.
    we always check the coin first or we go broke fast and waste all day looking like puppy chasing its tail.
    hint: below 2.9vdc is bad, 3.3v par.
    1: coin cell battery dead, stops list .
    2: HDD bad, most are bad after 5years, hard proof I have.
    3: test the HDD first, using smart app.
    4: if drive good make sure it is first in BOOT order in BIOS.
    5: if still fails reload the OS to that drive.
    lots more, can fail, but above is prime.
  • marc linx
    marc linx Apr 02, 2020
    you need to rest it.it would help you . must try this hope you would like it. best laptops for real estate agents
Olatunji Idirs
    New Friend:
    Problem Solver:
  • 10 Answers
Press the power battery for a while until u notice the device is off. The device will reboot and continue working. If not check or change the screen flex
Posted on May 21, 2019
Garth Bayley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Good Day
This sounds like you have lost your HDD or if you have just installed a new HDD this will be the message until you install an operating system.
Kind Regards
3 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: How to upgrade a new compaq presario SR2150NX?
Add more RAM, 512MB ram will slow your computer down because when you run out of ram the computer uses the hard drive as vitrual ram. I have 4GB in my Vista machine and it is faster than XP.
Another suggestion is to turn off the hard drives indexing. Right click on your "C" drive and unhook the "index this drive for faster searching" box.
Posted on Jan 05, 2008
Anonymous
  • 28 Answers
SOURCE: PC not recognizing monitors or keyboard
Try flashing the bios, which is found as step 3 on the flowing website. here.
If that does not work, make sure the connectors are not damaged, and ensure that all internal components, especially power cables, are properly seated.
~gnome
Posted on Jan 04, 2009
Rob Lauzon
  • 71 Answers
SOURCE: Compaq Presario SR2150NX doesn't turn on. Front
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Posted on Apr 15, 2010
Testimonial: "Veeery helpful. Thanks a lot!"
Computer won't boot. Message says Operating system not found. Tried Ctrl Alt Del and turning it off. What else can I try?
Hi there, My Toshiba had this in the users manual in all programs.As you start your Toshiba press the zero key at the same time.You can also buy a disk from Toshiba.You have to go into setup and change the boot order so that CD ROM is first in line in order to boot from a CD.Choose quick format.and follow the prompts.Do not chose repair and keep the same partition size.There will be a small partition for Toshiba stuff so just leave it there.Good luck and Thank You for choosing FixYa......................Darryel
Aug 11, 2011 | Toshiba Satellite L655-S5101 Laptop
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
I need the format
Follow the below steps to install XP
1. Insert Windows XP disc and reboot the computer. 2. Change boot order to "Boot from CD" or keep tapping F12 and change the first boot device to CD-ROM 3. Press enter when you see a message "Press any key to boot from CD" 4. You will see lots of things going on screen. Once everything loaded, you will see a message "Welcome to Setup". Press Enter. 5. Press F8 to agree license agreement. 6. Now, as you already have operating system installed, you will see a message "computer already has XP files" and will ask you to repair it. Press F3. WE dont wanna repair it. 7. In this screen, highlight C drive and press enter. 8. Press L to confirm delete. 9. Select first option "Format the partition using NTFS quick" and press enter.
Rest everything is self explainatory.
Now, it will copy the files and reboot the computer
Just follow the onscreen instuctions like Entering computer name .. CD key..
Thats it..
Apr 12, 2011 | Computers & Internet
It wont format, it wont let me delete or even add songs? what do i do?
There are two to reformat your device. Just follow these instructions
From menu of your device:
1. Turn on your Sansa C240
2. From the main options menu, select " Settings "
3. Select " Format " and " Yes "
Formatting Manually:
1. Turn off Sansa C240
2. Slide the " Hold " switch on the bottom of the device to the " On " position
3. Press and hold the " Play " button. Press and release the " Power " button.
4. Hold the " Play " button until the LED screen displays the message " About to format device."
5. Release the " Play " button and press the " Next " button once.
Try these steps and let me know if you manage to reformat your device.
I could instruct you on how to reformat this device on your pc just post back.
If these solutions helped you.. please rate this answer and leave some testimonial too.
Thank you
Nov 17, 2010 | SanDisk Sansa c240 MP3 Player
I get a black screen that say: Realtek PCI Express Gigabit Ethernet Controller Series v2.26 (090219) PXE-E61 media Test Failure check cable ****-MOF: Exiting PxE ROM No Bootable device- insert boot disk...
Apparently, the HDD has failed, that's why it doesn't find a bootable device and you can't restore te factory settings. You can try getting Hiren's Boot CD and use the testing tools to scan and fix the drive. Sometimes it just gets corrupted and returns to RAW format and just needs a format ( unfortunately you will lose all your data).
Nov 17, 2010 | Computers & Internet
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
I am trying to format c: and erase everything on that drive i dont have a boot disk however just the windows xp pro disk and i cant remember how to get into command prompt
You can't format the drive while Windows is running. Insert the CD, reboot, and follow the prompts to delete and re-add the main partition, then do a Quick format.
Nov 02, 2009 | Microsoft Windows XP Professional With...
I've Got a Dell 1525, but it won't start up, just get a blue error message screen. Any ideas????
its bugged or so ...ir its missing files that were deleted by the anti-virus...
so ...format and reinstall ....be sure that ya format at least the C partition ....cause if ya have a recovery cd ..it will go under the last installation and the problem will reappear
Oct 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
My nokia 6600 is sending bluetooth messages on it`s own
hi its a very common problem with 6600. u should flash ur mobile from a certified mechenic.OR u must try this method: first switch off ur mobile and switch on ur set while pressing (star key),(dial key or green key)and(number 3 key) till formating screen appear.after appearing formating screen leave the button and let format ur handset.
plzz rate me
Dec 22, 2008 | Nokia 6600
Insert simcard problem
Steps Turn your device off. Remove SIM card And MMC card. (actually not need to remove, but after format remember to format memory card and reboot phone) Press (3 + * + CallButton) Together. Turn your device on while you are pressing the three buttons. You should now see "Formatting .." word on the Screen! Leave the buttons now
May 07, 2008 | Nokia 6600
HP Compaq Presario SR2150NX PC Desktop Logo
364 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
