Question about RCA F27450 27" TV
Anyway I can have closed caption on rca colortrak 200 tv?
Posted by davinci1776 on
  • DigitalPlus1
    DigitalPlus1 Apr 19, 2011
    Are you using a cable/ satellite box or OTA digital tuner?
2 Related Answers
Anonymous
  • 133 Answers
SOURCE: Rca remote tv code
I own a One-for-All universal remote, and my booklet says the setup code for a RCA TV (without a built-in DVD or VCR) is one of the following numbers: 0047, 0090, 0679. I can not guarantee that these numbers will work with your remote, but it is worth a try.
Posted on Jul 06, 2008
Anonymous
SOURCE: I have an RCA colortrak plus Model # F32632SB that scrambles
Volume wont go down and lost remote
Posted on Mar 26, 2011
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
Need Closed Captioning
If you have the original remote control, there will be a button marked "CC", and pressing it once, the closed caption funciton will turn OFF, and for an other press, it will re-appear. Now, here you are using a universal remote control. So it will be difficult to make closed caption. Try to enter its function menu by using present remote control, where you can make this funicion OFF, if you could enter into it.
Jun 02, 2013 | Insignia NS-RTV32 32" TV
How do I turn off closed caption on a RCA GUIDE PLUS GOLD GEMSTAR?
Press the "CC" button on the remote controll once. If there is no such button on the remote control, get into Menu of the TV, surf thorugh, come to closed caption optione seclect fucntion, and make Closed Caption to OFF.
Apr 09, 2012 | RCA Televison & Video
How do i take the closed captioning off of my tv?
Hello
Enter the main menu
Highlight Preferences
Select closed captioning and press OK.
Highlight Caption Display and press OK.
Select Closed Captioning off and press Ok
That is all.
OK.
Jan 27, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
How do I turn off the close captioning on a Sansui TV using an RCA universal remote
codes for sansui from an rca remote are 1191,1208,1282. while pressing and holding the tv key, enter one of these codes. release the tv key and then press on-off key. then press tv key then on-off key again. if set turns on and off, we got the right code. then just use your menu to find closed caption and adjust from caption or text to off.
Nov 14, 2009 | Televison & Video
Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Nov 27, 2008 | RCA TruFlat 27F520T 27" TV
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
RCA F27450 27" TV Logo
201 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
