Question about Samsung SCX 4521F All-In-One Laser Printer
I have samsung scx-4521f i need the part numbers for the ac power supply and the formatter board can you help glenn cross
Posted by service934 on
saroj_saroj7
    New Friend:
Give me software cd of samsung scx-4521f
Posted on Apr 19, 2011
  • saroj_saroj7 Apr 19, 2011
    how to download ?
Warming up always
plss change your fuser termister .or formatter board
Oct 01, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx 4521f warming take too much time
take the back cover off. you will see in the power supply there is one capasetor which need replacement
Dec 05, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Samsung printer scx-4521f need smarthru4 scanner software
need a reliable site to download smarthru4 scanner software for Samsung printer scx-4521f
Oct 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx 4521f not giving ready signal
replace electrolytic capacitors on secondary of power supply. 1200uf 16v . replace with 30v also replace 47uf
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to send fax in samsung scx-4521f
The SAMSUNG SCX-4521F is an efficient fax. It also has the ability to send a fax document directly from your PC via the supplied SmarThru 4 software.
Save time and paper by simply clicking on the ''PC Fax'' button from your computer.
Nov 15, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F Possibly lost its power? When
If it just make tick sounds, but does not power up and does not do its normal startup, it probally the power supply board on this printer has failed. This printer like most modern electrical appliances has a switching power supply. The ticking sound is the power supply trying to start, but it senses a fault and shuts down and tries to restart.
I had a similar problem with my printer, though it not the same model (CLX-3160) but the same manufacturer Samsung. I took mine appart and found that one of the capacitors on the power supply had failed. It was blown and the top of the capacitor popped open. I am not saying this is your problem but it would be the first thing I would check if you want to get this fixed. Otherwise, look for a new printer.
Hope this helps.
Jun 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F Multifunction wont power on
Power supply on the printer is faulty. It might only be a fuse though, but you have to disasemble the printer to check the fuse.
Aug 04, 2009 | Samsung SCX 4521F All-In-One Laser Printer
18 month old Samsung SCX-4521F Multifunction printer wont power on at all. I've tried multiple outlets and turning on and off, nothing registers on the screen, completely dead. Any ideas?
you will have to be a bit tecnical.
open the back of the unit.
on your left is the power supply.
look clously to the parts on the board you will see near a heat sink is a capasitor wich is faulty. replace it
Samsung SCX 4521F All-In-One Laser Printer Logo
113 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
