Question about Yamaha YST-M15 Computer Speakers
Sub-woofer operation I have an old set of GREAT Yamaha computer speakers including sub-woofer YST-M15. The sub-woofer doesn't stay on if not in use for a while. However, when I play a .wav , etc. file it USUALLY turns on. Is it triggered by the sound or do I have a short in the on-off button. I've never had a sub-woofer like this. It doesn't turn on for very short .wav files. Please e-mail me [email protected] and thanks for your help!
Posted by atrekker1 on
5 Related Answers
Anonymous
  • 236 Answers
SOURCE: subwoofer
the best connection is to connect your sub to the output connector (subwoofer) of your HTR. it should have one. But you can also connect parallel to the speakers, any of right or left speakers or both. i normally connect to the speaker set B if thorugh the speaker connections.
Posted on Mar 31, 2008
tech240
t support
  • 169 Answers
SOURCE: bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Posted on Sep 20, 2009
Anonymous
SOURCE: I need the drivers for Yamaha YST-M15 computer speakers.
The speakers just plug into the sound port on the back of the computer. I never found a need to download any drivers for the YST-M15s that I have. You may not either. Why do you think you need drivers?
Posted on Feb 15, 2010
Marek Podmaka
  • 127 Answers
SOURCE: I own a Yamaha RX-V461 and since making a few
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Posted on Mar 02, 2010
PickyPrick
  • 52 Answers
SOURCE: i just bought a yamaha
sell the bose sub, buy a nicer yamaha sub, enjoy the 200 bucks you have even after you buy a new speaker.
Posted on Jan 29, 2011
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
Will the woofer work without the other two speakers?
There is no point.
The woofer(sub woofer) just delivers the bass. You usually put the sub woofer out of the way under your desk.
Without the other speakers you would just get the thumping bass and no treble
Aug 30, 2010 | Yamaha YST-MS201 Computer Speakers
I need manual for my Yamaha YST-M15 speaker
Hi! You may click here for the manual. Thanks for visiting FixYa.com!
Jun 05, 2010 | Yamaha YST-M15 Computer Speakers
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Dec 23, 2008 | Yamaha YST-M15 Computer Speakers
Yamaha YST-M15 Computer Speakers Logo
60 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
