Access is at the bottom of the water heater. There is a little cover you will have to take off. Look for the gas valve. (its where the gas will come in to the water heater) Follow the two lines that come off he bottom of the valve. They will lead you to the burner (big line) and the pilot(smaller line). The pilot is what you are looking for.
1. locate the pilot (it will be 8" or so in to the water heater)(right next to the burner)
2. Turn knob on top of gas valve to "pilot"
3. Push down the knob on top of the valve that you just turned to "pilot" or there may be a lever right next to the knob on some models
4.with a long fireplace match or bar b que lighter, while holding the knob down, reach your lighter to the pilot assembly. you may smell a little gas.
5. The pilot will light, do not let go of the knob for 30-45 seconds
6. After a few seconds let go of the knob and turn it to "on"
7. Check your thermostat make sure it is not on "vacation" and turn it up to see if the burner ignites.
You are ready for hot water if all works. Hope this helps you, have a good day.
