Lexmark 6570 printer won't install on older XP machine
Have this new multi-function to share on a small office network with mix of machines. Software REFUSES to load on an old Presario saying it does not meet minimum requirements - Has 500MHZ PII. OK on newer laptop. Don't want to do anything exotic, just share printing. I can't believe the printer installation software is so inflexible in deciding that my processor can't drive their driver (must be one heck of a driver). The Presario updated just fine to XP, I was not aware that drivers will refuse installation based on system resources. Have plenty of disk space, etc.
Anybody got any ideas or a clever workaround?
Posted by robbiegray on
richie46
    Top Expert:
  • Office Equip... Master
  • 12,962 Answers
Nope. The driver is like the tranny on a car which connects the motor to the rear wheels. On a computer the driver connects the peripheral to the OS - And if you do not have the correct driver for the OS you ain't gonna go anywhere!
And Lexmark is not obligated to provide a driver for an OS it was not designed for. End of story.
Posted on Apr 09, 2017
4 Related Answers
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
1. Right click on My Computer and select Properties.
2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
5. Click the Details tab.
6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
If you are using an USB connection, they need to be at least USB 1.0 compliant.
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
1. Click Start, Run.
2. Type MSCONFIG on the Open line, then click OK.
3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
Posted on Mar 15, 2008
Anonymous
  • 111 Answers
SOURCE: HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Posted on Oct 06, 2008
marked
Mark Gil
  • 6487 Answers
SOURCE: I need a Lexmark 9350 printer driver software
You can download the printer software from this link , so you can install the printer to your computer
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Nov 17, 2008
billspeer
Bill Speer
  • 180 Answers
SOURCE: a drive for panasonic KX-FLM551/FLB751 ?
I checked their website http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/model.KX-FLM551
It doesn't list any Vista drivers yet. Have you tried running it in Compatibility mode for XP?
Posted on Jan 14, 2009
Please give me an impact analysis of upgrading from office 20003 to office 2010. I have never used 2010 before. The organization has about 3000 users.
I maintain computer labs for about 4000 people at a university in the US. We recently made the move from Windows Office 2007 to Windows Office 2010. This move was not terribly difficult, but we have experienced some glitches now and then from the software.
Moreover, the interface for Office 2003 is much different in Office 2010. This poses a problem for users having to relearn how to do tasks that they once knew very well.
One other thing to consider is that Office 2010 uses more resources than Office 2003. If your computers are very old, then they may have problems running the software. The hardware resources utilized by Office 2010 are almost identical to the resources needed by Office 2007.
Good luck,
-Spencer
Feb 28, 2011 | Microsoft Office 2010
Can I share my Scanner on a Local Area Network?
no, but what you can do is hook it up the computer and share that file to the network. for example, if you scan it, you'll have to use that computer to load the images to that file. and all the other computers on the network can see that file. you can do that. let me know if you need more info.
Oct 17, 2009 | Canon DR-2050C Path-Through Scanner
Canon IR c3200 - CAn't dNetwork Scanning (Simple - Shared Folder)
Hi,ok you have to load the clolor network scangear exe file.If the scangear is installed,click on discoveron the color network scangear tool.It will detect the machine,select the machine.
Then it will be ready to scan into word or other programs.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
Problem with opening templates in Word 2007
I think you need a service pack with some old libraries supported.. This is quite common when upgrading to higher levels of VB.. eg 3 to 5 or 6 etc. If you have the un-compiled code, it can be fixed.. Or load an early version of VB will also fix it. If you have the code, send it to me. Let me know how it goes.. Rgds,
May 12, 2008 | Microsoft Office Professional 2007 Full...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
How to Network the scan function of a Gestetner DSm635
The only real problem would be finding the software driver for your machine.When your driver for your scan function is loaded it will assign an IP address for the scanner.without the software,your out of luck.I'll look online tonight for it and let you know if I find it.
Mar 10, 2008 | Gestetner DSm635 Copier
Can't see other PC's on my network with Microsoft Vista basic
set up file sharing and make sure the laptop is set to "private" not "public" in the Networking and Sharing Center.
Nov 20, 2007 | Microsoft Windows Vista Ultimate Edition
Delayed write failed
First reinstall lan card driver if it is shown same error than change the lan card . good luck
Sep 11, 2007 | Microsoft Office 2003 Basic Edition...
"delayed write failed" in office 2003
You will get a delayed write failed when the network is no longer connected and the user tries to save the file. are you noticing any other issues on your network?
Sep 09, 2007 | Microsoft Office 2003 Basic Edition...
174 people viewed this question
Ekse
Marvin
Marvin
