Briggs & Stratton Briggs  Stratton 6200 Watt Portable Generator Logo
Posted on Oct 22, 2017
Briggs Elite series, 8000 watt, 13000 starting watt, onlt 3years old, recently pulled from shed for use and it is not putting out any voltage, cranks and runs fine, there is a drop from the step on my shed and it could have jarred a little getting it out, was working fine. I tried resets and also turning power switch on and off several times.
4 Related Answers
Anonymous
  • 169 Answers
  • Posted on Dec 08, 2008
SOURCE: Brand new briggs & Stratton 8000 watt generator....
I posted an answer that should help here.
Carl
John Trevino
  • 1420 Answers
  • Posted on Dec 18, 2008
SOURCE: High voltage low cycles
I worked at a tool rental center while going to college and learned how to service generators. Most appliances/tools require 50 to 60 cycles at 110 to 120 v. Your engine was designed to give maximum horsepower at 3600 rpm. Adjust the engine speed to produce 60 cycles and the engine should be at 3600 rpm and producing around 120v max. (Some special generators were designed to produce 230v 180 cycles, check manual) If your generator incorporates capacitors check them for at least 95% of printed uf value. They should be removed from circuit for testing. If there are two caps and one is weak make sure the new cap reads close to value of remaining cap. Finally there is usually a voltage regulator that varies the power to the armature magnet trying to maintain steady voltage depending on amp draw and engine condition. This regulator has no adjustment and is pass or fail type of item. Good luck, enjoy
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jul 10, 2010
SOURCE: I,ve got an Briggs and Statton elite 10000 watt
Does it appear to be running as fast as it always did, as in RPM's are same as usual? If there is a fuel problem and rpm's decrease due to that, voltage will drop as well. Other causes may be internal problems with generator circuits etc, and will need technician to troubleshoot it properly.
You can try increasing the throttle manually and see if voltage comes up.
John Trevino
  • 1420 Answers
  • Posted on Sep 09, 2010
SOURCE: Briggs and stratton 8000 watts
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
We have a Briggs & Stratton Elite Series 5500 watt 8200 starting watt generator, it locked up on us last winter & we can't find out why, what can we do
If the engine is locked, it could be any one of several things. Most are rather expensive, like: seized due to no oil; broken rod; bad valve, etc. An engine mechanic is going to have to troubleshoot it for you.
Briggs 6200 elite generator. Starts runs good no ac output and display is blank
http://www.ebay.com/itm/BRIGGS-STRATTON-GENERATOR-OPERATORS-MANUAL-ELITE-SERIES-6200-RUNNING-WATTS-/401042177246 $14.95
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
Briggs and stratton 8000 watts generator, the output of the 120 is only 102. How do I adjust the output?
I,ve got an Briggs and Statton elite 10000 watt generator, it wont supply enough power to the house evrything is dim lights etc, Ive used it amny times before it will pretty much run the whole house...
2helpful
2answers
Putting out half the volts
My 13 hp 8000 watt is not putting out any power dose it need to be exsited and if so were do i do it at?
Top Briggs & Stratton Electrical Supplies Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
