Ubi Soft Catz 5 (Windows) (680901) for PC Logo
Question about Ubi Soft Catz 5 (Windows) (680901) for PC
I have petz 5, but every time I try to load it up the yellow bar freezes 1/3 of the way every time and a microsoft windows box pops up that says: Petz 5 has stopped working ( I kinda realised. ) Problem name: APPCRASH. I have moved all of my hexies away and restarted the game a billion times but it still wont work. The only thing i havent done is uninstalled it but i dont have a cd. is there any other way i can fix it?
Posted by blue_raven19 on
5 Related Answers
Anonymous
  • 202 Answers
SOURCE: Petz 5
Have you turned off any virus protection/spyware protection before you re-installed? Make sure the program is uninstalled in add/remove programs. Check for any spyware or viruses on the machine. Let me know what happens. Good Luck, Tim
Posted on Feb 24, 2007
Anonymous
SOURCE: Petz 5
are you importing the files? i don't know. look for a walkthrough
Posted on Aug 22, 2008
Anonymous
SOURCE: Petz 5 help!
at the moment you either would have to create new petz or try installing the game again. the way to see if you saved them is to go into the saved petz folder and find files of your animals , if they are there unlock and download any zip files and they should do it for you
Posted on Nov 02, 2008
Anonymous
SOURCE: Dogz/Catz 5 compilation Vista Help
Firstly, open a folder. You need to click on 'Organize' >> 'Folder and Search Options'. On here click on the 'view' tab, then check the box for 'Show hidden files and folders'. Click OK on this.
Next go onto C: and click on your user name, then click on AppData.
In here, click on 'Local' >> 'VirtualStore' >> 'Program Files' >> 'Ubi Soft' >> 'Studio Mythos' >> 'Petz 5' >> 'Adopted Petz'.
Here is the file path if you need it:
C:\Users\Your User Name\AppData\Local\VirtualStore\Program Files\Ubi Soft\Studio Mythos\Petz 5\Adopted Petz
Hope this helps!
Jenn xo
Posted on Jan 12, 2009
Anonymous
  • 19 Answers
SOURCE: Petz 5 problem
Did you "cheated" with the calendar on your PC?
In other words: Did you traveled trough the time on your PC (the virtual clock)
If you did, there's no hope for your petz.
Always make a back-up of your petz everytime you play Catz 5
Posted on Jun 02, 2009
3helpful
3answers
I downloaded Catz 4 on my Windows 7 PC and it freezes when i try to adopt a pet.
You'll need to go here. Download the second patch and install it. This will update Petz 4 to Petz 4.2. This patch was originally meant for XP, but does fix Vista and 7 too problem.
1helpful
2answers
Petz 5 won't load
Try Inserting The Disk And Instead Of Loading It Go On My Computer And Petz 5 And Then Click Launch :)
4helpful
3answers
Petz 5 not working. error message comes up
When you unintall Petz 5 you need to not save the petz, which is an option just before it starts uninstalling. Unistall, Then install it again, and run the game from My Computor, Petz, then play.
hope it works for you.
Petz 5 not working.
Right-click on the Icon > Go-to Properties > Click the "Compatibility" tab > Click the check box next to "Run this program in compatibility mode for:" and select Windows 98 or Windows XP if available.
You may need to disable visual themes or other options.
Hit apply once you are finished configuring.
Loading on to petz5, windows tells me program has a problem
Unistall, click 'no' to 'do you want to save your petz' You will lose all ur petz, but.. ts thw only way i know that works..
Reinstall, and play the game from My Computor, Petz. play. You will need to have ur disk in whenever you want to play.
Hope i helped
35helpful
4answers
Hope this helps!
Jenn xo
2answers
Dogz 2006 Version Freezes when I select Load from it's menu.
Yep - fixed it already. Went to other blogs and found another setting to change in the same dogz.ini file.
Have to change to read the following:
[Engine.Direct3D]
AllowFullscreenAntiAlias=0
If you have the value '1' change it to '0'
My daughter has restored her faith in my computer savvy as a result! Win-win.
Ubisoft needs to update their support.
truly,
Dogz_Dare
4helpful
3answers
Dogz 5 Won't Work!
This happened to mine 2. I uninstalled it, but the folder was still there, so I went on search, local disk, and searched ubi soft then deleted it. After that it worked, except I've noticed if you press save pets when uninstalling, it doesn't work.
If I want to keep my pets, I go into the ubi soft folder, adopted petz, then I drag my pets to a new folder I make on the desktop. When the game is reinstalled, I put the pets in the folder back into the adopted petz folder.
This has been the solution for me, but I don't know if it will work for others. Good luck!
Petz 5 won't load properly
your operating system does not support or screen resoulation does not support.
Open Questions:
See all Ubi Soft Catz 5 (Windows) (680901) for PC Questions
Top Ubi Soft Computers & Internet Experts
Mehandi Husain ...
Tom Chichester
Canadian VC
Canadian VC
Level 1 Expert
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
