SOURCE: Im trying to connect my
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
SOURCE: hello. I can't seem to
1. Turn headset
off. Press and hold until solid light comes on.
2. Activate
Bluetooth on your phone.
3. Search for
Bluetooth devices and select Jabra BT500.
4. Press ‘OK’ on the phone ,If the
phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank You
SOURCE: I purchased the Jabra BT2035
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
SOURCE: The device is Jabra 650s Headset and I am trying
Hi ambahaziq,
Try here:
http://www.jabra.com/CP-CP/support/Pages/JabraPCSuite.aspx
Install the suite, it has integrated drivers that should make it possible.
Really hope it helps, I had a similar problem last year.
Kind Regards :-)
* If you found this solution helpful, please accept it
