2003 Hyundai Santa Fe Logo
Posted on Aug 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 Hyundai Santa Fe Digital Clock Light won't work
  • 2 more comments
  • Anonymous Dec 22, 2008
    I have the same problem. It comes on early in the morning and then goes off.
  • Anonymous Mar 16, 2009
    the light to the digital clock comes on when it feels like it (intermittently)
    how do i resolve this problem
    2004 Hyundai santa fe
  • gianacone Apr 04, 2009
    I have the same problem with the clock on my Santa Fe.
  • jackson7 May 19, 2009
    2003 hyundai santa fe - the 15amp ecu+ fuse keeps blowing every time i try to start the car, car will crank but will not start.
Joseph Bonomo
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 87 Answers
  • Posted on Mar 27, 2009
Joseph Bonomo
Expert
Level 2:
Cheetah:
Answers
87
Questions
0
Helped
38483
Points
206
Hi it is the clock itself. hyundai santafes as a major issues with these. The only way to fix it is to get a new clock installed
  • stantarasek Feb 15, 2011
    Replaced once after 2 yrs. -covered under warranty. After 5yrs. the clock does not keep time and needs to be replaced AGAIN! Estimated cost $125.00. I think Hyundai has a real problem with this clock, but won't admit it. A RECALL is in order.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3449
Points
I have the same problem! Mine resets to 1:00 every time I restart the car.
1 Related Answer
Anonymous
  • 1665 Answers
  • Posted on Jun 08, 2008
SOURCE: 2003 Hyundai Santa Fe clock stopped working
1. Be sure there is no play in the fuse holders, and that the fuses are held securely. 2. Are the fuse capacities for each circuit correct?
2helpful
The cruise control and the hooter does not work on my steering please help
Does the air bag light come on as well ? The clock spring in the upper steering column is use so your steering wheel button's have power an you can still turn the wheel from right to left . They break no an then ! How to replace clock spring in 2006 Hyundai Sonata
tip
What you need to know about Hyundai
I am a mechanic ..most people ask questions about these foreign hyundai motors ..below is an example of engines that basically if you ask about a Hyundai Xg 350 ,xg300 ..well allow me to hammer 90% of your questions in case you want to grab another motor ..these motors listed will work on 90% of all hyundai products ...Look at the starter sizes ,,all the same for the selected models ..then look at the motor sizes ..This will help you in solving some problems most do not give the specific questioning
100% NEW REPLACEMENT STARTER
FOR
STARTER
12 VOLT / CW ROTATION / 8 TOOTH DRIVE
REPLACES:
MANDO M62957
VALEO TM000A14401
BOSCH REMAN SR4118X
BOSCH NEWMAN SR4118N
HYUNDAI 36100-37210
FITS ON:
HYUNDAI
2001 SANTA FE 2.7L ENGINE
2002 SANTA FE 2.7L ENGINE
2003 SANTA FE 2.7L ENGINE
2004 SANTA FE 2.7L ENGINE
2005 SANTA FE 2.7L ENGINE
2006 SANTA FE 2.7L ENGINE
2003 SANTA FE 3.5L ENGINE
2004 SANTA FE 3.5L ENGINE
2005 SANTA FE 3.5L ENGINE
2006 SANTA FE 3.5L ENGINE
2002 SONATA 2.7L ENGINE
2003 SONATA 2.7L ENGINE
2004 SONATA 2.7L ENGINE
2005 SONATA 2.7L ENGINE
1999 SONATA 2.5L ENGINE
2000 SONATA 2.5L ENGINE
2001 SONATA 2.5L ENGINE
2003-2008 TIBURON 2.7L ENGINE
2005-2008 TUCSON 2.7L ENGINE
2001 XG300 3.0L ENGINE
2002 XG350 3.5L ENGINE
2003 XG350 3.5L ENGINE
2004 XG350 3.5L ENGINE
2005 XG350 3.5L ENGINE
KIA
2004 AMANTI 3.5L ENGINE
2005 AMANTI 3.5L ENGINE
2006 AMANTI 3.5L ENGINE
2001 MAGENTIS 2.5L ENGINE
2002-2006 MAGENTIS 2.7L ENGINE
2001 OPTIMA 2.5L ENGINE
2002 OPTIMA 2.7L ENGINE
2003 OPTIMA 2.7L ENGINE
2004 OPTIMA 2.7L ENGINE
2005 OPTIMA 2.7L ENGINE
2006 OPTIMA 2.7L ENGINE
2002-2005 SEDONA 3.5L ENGINE
2005 SPORTAGE 2.7L ENGINE
2006 SPORTAGE 2.7L ENGINE
2007 SPORTAGE 2.7L ENGINE
2008 SPORTAGE 2.7L ENGINE
on Oct 24, 2013 • Hyundai Cars & Trucks
Won't start santa fe
do u check ur wires or u can change ur plugs an u can see if ur fuel pump comes on
3helpful
My 2003 Santa Fe will not stay in 5th gear! I have a new clutch!!! What's up??
This is not a clutch problem this is a worn part in the transmission causing this, have the transmission removed and torn down and inspected to see what is worn out and affecting the 5th gear.
2helpful
Hyundai santa fe clock & compass stopped working
Check fuses... replace as needed. If fuse(s) are blown/keep blowing, a short exists and diagnosis/ troubleshooting is required.
Hyundai santa fe 03 running problems
If your Santa Fe has a V6 engine 2.7L , it sounds like you have an ignition break down happening. You will need to renew all the ignition wires and check the two coils also for arcing .
Digital Clock
yes it is a common problem it needs a new clock thats the only fix sorry
1helpful
3answers
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
