Question about Kenneth Cole Watches
Battery need for kenneth cole kc3945 - Kenneth Cole Watches
Posted by sgesualdo on
5 Related Answers
Anonymous
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
Anonymous
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
saturnd00d
  • 5 Answers
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
How to change the battery in a kenneth cole 3504 watch
you have to open caseback, inside close to the battery see one tiny metal piece pressing & holding battery, you need a tiny pin to pry that metal piece battery will come out put new battery on then press VERY GENTLY 9k=
May 13, 2014 | Kenneth Cole Reaction KC3504 Watch for Men
My kenneth cole KC2555 watch doesnt give the correct time even after adjusting it. How can i fix it?
If it's more than a year old it may need a fresh battery. Any watch or jewelry shop can do that for you for about $8.
Apr 13, 2010 | Kenneth Cole Women's Watch
Lost battery for Kenneth Cole watch style 3837. Need to know what replacement battery fits watch.
After very close inspection, I was able to read (with magnification) the worn data on the watch case which had the battery number inscribed.
Sep 12, 2009 | Kenneth Cole Watches
Watches Logo
62 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
